Thread: Power being drawn by battery??
Results 1 to 4 of 4
  1. #1 Power being drawn by battery??
    GT Level Member des19's Avatar
    May 2011
    Ontario
    Ok so my battery died a few days ago so first I replaced the battery, few days later it dies again...so now I replace the alternator which is the only other thing it could be. I brought it to ct and they said everything is running good but the battery is still having a very small current being drawn from it even with the all new alt and batt.
    They couldn't tell me what so I am wondering wtf it could be. I have hids, aftermarket deck and amp, subs...These have all been in the car for years though with the car battery never dieing. Also I have those switchback leds in the turn signal and one recently started hyper flashing which means the resistor either went out or disconected some how (for those of you who know how these are installed). I also have a boost gauge which has a backlight with the power spliced to the radio power and the ground (also been installed for over a year)
    any thoughts?
  2. #2 Re: Power being drawn by battery??
    St. Louis
    Might be time to start pulling fuses one at a time to see which one is causing the constant draw when the car is off. I know this issue has come up before, so maybe try a quick search and see what that turns up.
    Here's one that came up under the search of "battery drain"
    http://www.grandprixforums.net/new-b...ing-69549.html
  3. #3 Re: Power being drawn by battery??
    May 2011
    Ontario
    Quote Originally Posted by FordMan77 View Post
    ya not looking forward to this
  4. #4 Re: Power being drawn by battery??
    It's pretty easy to pull a fuse.
  1. '02 AutoStart Problem - battery power
    By Lakerman in forum General Tech Discussion
    Last Post: 02-01-2011, 08:18 AM
  2. Trying to tun my power wire to the battery
    By Zak97GT in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2011, 08:37 AM
  3. Power wire amp to battery
    By yeacashgpgt2002 in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2010, 11:45 AM
  4. battery/power help on a 98 GTP
    By shawnz90 in forum General Tech Discussion
    Last Post: 12-02-2009, 06:34 PM
  5. Convert a GP to battery power. Could it be done?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-03-2008, 09:24 PM
