Thread: Performance PCM on stock gt
Results 1 to 9 of 9
  1. #1 Performance PCM on stock gt
    Aug 2012
    Tukwila, Washington, United States
    Does it do any difference?
    Can it harm the engine?
    Btw what's does it mean shift points 5800-6000?
    Here's the features from 3800performance.com
    FEATURES:
    - Speed limiter removed
    - 3-1 and 4-2 skip shifts
    - Transmission line pressure increased
    - Shift points moved (5800-6000rpms)
    - Fan turn on points altered:
    - 186 degree turn on
    - 2 minute fan on at key-off (this feature activates when engine coolant is 179 degrees or greater)
    - MAF calibration adjusted for proper operation and year
    - Fuel/spark adjustments:
    - En-richens fuel delivery for critical problem areas
    - Provides a consistent power gain across the entire power band
    - Reduces spark retard (knock retard)
    - Removes “40MPH WOT lag”
    - Dynamometer testing has shown approximately 8-12HP in 60 degree temperatures on a development vehicle using 93 octane fuel.
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: Performance PCM on stock gt
    Yes and yes..
    Did you do that coolant flush yet?
  3. #3 Re: Performance PCM on stock gt
    Aug 2012
    Lol hahahahaha not yet. Hahaha
    I'm moving apartment so I have so much stuff to do.
    Thanks for reminding me haha.
    And I'm asking here cause 3800performance emailed me it won't do any harm to the engine after asking them the same question.
    (I trust u guys better)
    How these features are harmful
    Does it worth the hp?
  4. #4 Re: Performance PCM on stock gt
    Higher trans shifting keeps the engine rpm up longer. We have known oiling deficiencies. Stock motors don't rev fast, and don't like holding high rpm for a long time. Loosening up the TM in the trans settings makes it easier to tear up the trans.
    Will it overall hurt your car, likely not. Will you like the feel, most likely.
    You can't get this until that coolant flush is done. I'll rename you, dog you, and remind you until it's done.
  5. #5 Re: Performance PCM on stock gt
    Aug 2012
    Haha
    You make me laugh all the time with that coolant flush.
    Anyway about the PCM. Il try to ask them to take down the rpm cz it's really high.
  6. #6 Re: Performance PCM on stock gt
    Dec 2012
    Where 4T65E's were born
    Are you positive that this stuff will clump with green coolant like the original dex-cool does? I could mix them in a cup and see what happens, if that's even a valid experiment.
    Sold.
  7. #7 Re: Performance PCM on stock gt
    Aug 2012
    Save ur time. Today I checked my coolant and I saw something like mud on my rad cap. That's the sludge
  8. #8 Re: Performance PCM on stock gt
    Jan 2013
    michigan
    you should follow this then add a pcm
    http://www.grandprixforums.net/safel...0-a-67580.html
  9. #9 Re: Performance PCM on stock gt
    Dec 2012
    Well, flush asap. Maintenance before mods.
    Sold.
  1. 3.4 stock performance mods
    By Jesse III in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-28-2013, 04:38 PM
  2. Looking for stock 04 gt performance parts
    By Jolin in forum Introductions/Noob Questions
    Last Post: 10-06-2009, 02:05 PM
  3. What should i do, performance or stock
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 01:29 PM
  4. Best performance part you can buy for a stock GT
    By Dohner in forum PCM Tuning
    Last Post: 02-22-2008, 02:01 PM
