Thread: Possible Trans or Tune Problem?
Results 1 to 20 of 20
  1. #1 Possible Trans or Tune Problem?
    SE Level Member BigKev2403's Avatar
    Feb 2013
    Cleveland Ohio
    So I just bought this car a couple days ago. So far am very happy with it. The seller told me that there was a shift kit installed on this car, And it was tuned, so I'm not sure if what I am going to explain has to do with it.
    If I am going 60 mph and then let off the gas the car coasts at 1000 RPM
    At that same 60 mph coasting when I press the gas nothing really happens until about 2500 RPM
    If I am trying to cruise at 70 mph I'm right around 2900-3000 RPM.
    These numbers seem awfully high does that sound about right to you guys?
  2. #2 Re: Possible Trans or Tune Problem?
    You are missing 4th gear
  3. #3 Re: Possible Trans or Tune Problem?
    Feb 2013
    Cleveland Ohio
    ....oh boy
  4. #4 Re: Possible Trans or Tune Problem?
    gardner,mass
    Quote Originally Posted by BigKev2403 View Post
    welcome to owning a 3800, get ready to rebuild and put in a hardended 4th
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  5. #5 Re: Possible Trans or Tune Problem?
    Feb 2013
    Cleveland Ohio
    That's gonna run me a ton won't it
  6. #6 Re: Possible Trans or Tune Problem?
    You can just drive it if it doesn't bother you. It won't hurt anything except your gas mileage.
  7. #7 Re: Possible Trans or Tune Problem?
    Feb 2013
    Cleveland Ohio
    Okay I'm glad you said that. Because I truly have no money to rebuild this thing right now. Thank you for your answers tho.
  8. #8 Re: Possible Trans or Tune Problem?
    It's not that bad. You can replace the part if you'd like.
    http://www.grandprixforums.net/how-t...ess-54448.html
    TripleEdgePerformance sells the shafts.
  9. #9 Re: Possible Trans or Tune Problem?
    GT Level Member Shiftingshaddow's Avatar
    KC
    i'm really sorry man. happened to me last year.
    it will kill your gas mileage. expect 4 mpg loss highway and same city. if you have it in 3 driving highway speed the rpm needle will not go down as far as fast so that should help that part.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  10. #10 Re: Possible Trans or Tune Problem?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Bought my car at 168k....trans lost third at 172k then it completely won't out at 175k
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  11. #11 Re: Possible Trans or Tune Problem?
    Feb 2013
    Cleveland Ohio
    I don't know if this will change anything but I talked to my buddy about this possible problem and he has a $4,000 SnapOn scan tool and it registered that we were in 4th gear...
  12. #12 Re: Possible Trans or Tune Problem?
    no way your in overdrive and running at 3,000 rpm's doing 70 mph. its really a 3 speed trans with a over drive, why they call it 4th gear ill never know. the 4 th gear hub splines wear off and bye bye overdrive. like posted above, its fixable.
    in o/d at 70 im only doing 1800 to 2,000 rpm
    i lost 3 rd in my trans, so i had to nail it to 45 plus mph in second gear, then let off the gas and let o/d catch then i could drive at highway speeds like normal. sucked not having a passing gear lol
  13. #13 Re: Possible Trans or Tune Problem?
    Hook the scantool back up and look at the calculated gear ratio. Third is 1:1 and that's what you will find is occuring. Yes the pcm selected and moved the soleniods for 4th to be engaged and yes the clutches are engaged. The splines on the shaft that the clutches drive are stripped. Which keeps 4th from engaging.
    GM did a cool thing with the trans in that area.
    4th hub shaft. the wider part is where the clutches sit on and drive this shaft.
    The smaller splined end is what drives the trans for 4th. See the mark/much less material? I have seen these stripped smooth.
  14. #14 Re: Possible Trans or Tune Problem?
    KC
    here's a question....is there a way to keep it from getting stripped? is it heat related or just wear and tear from normal use? if the fluid is serviced and filter changed on schedule will it help?
  15. #15 Re: Possible Trans or Tune Problem?
    It's just normal wear and tear.
  16. #16 Re: Possible Trans or Tune Problem?
    they make a hardened 4 th gear hub now, so it just the older cars that are affected by this, the new part will out last the rest of your tranny.
  17. #17 Re: Possible Trans or Tune Problem?
    KC
    is it industry standard or are there some kits or parts manufactured factory quality?
  18. #18 Re: Possible Trans or Tune Problem?
    ive never had to order one my self, but im sure its sold saying its hardened.
    cant see why they would still make a part like that when it fails.
  19. #19 Re: Possible Trans or Tune Problem?
    KC
    oh, but there are others.....
  20. #20 Re: Possible Trans or Tune Problem?
    97-02 The part was not hardened. That's about when GM started seeing enough of them strip out to act on it. Starting some time in 03 (late 02 builds often have non hardened) GM changed this shaft to a hardened one. Once that went in, things were good.
    Tripleedgeperformance and a bunch of other sell them as well.
  1. Trans problem
    By Logan541 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-02-2011, 02:41 PM
  2. GTP Trans Problem
    By 04srmGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2011, 04:03 PM
  3. Trans problem
    By Pontiac99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-23-2009, 01:00 PM
  4. trans problem in a 00 gtp
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 05:16 PM
  5. Seafoam Trans Tune any good?
    By 99BluGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2008, 09:01 AM
