Thread: is this a normal heat level for the car? look at this
Results 1 to 14 of 14
  1. #1 is this a normal heat level for the car? look at this
    Aug 2012
    Tukwila, Washington, United States
    Attachment 10829
    this is after 20 minutes driving highway 60mph
    54f outside.
    fan is all the way on my feet.
    it seems like the car get hot to the quarter only when car is on idle for about 25 min.
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: is this a normal heat level for the car? look at this
    Yoga city
    my gtp ran like that all the time, i figure the therm was incorrect.
  3. #3 Re: is this a normal heat level for the car? look at this
    SE Level Member Iceman83's Avatar
    Jan 2013
    Livermore, KY
    My '99 does the same thing. Has for 8 years.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    During the summer my GT runs at almost 210 and during the winter just above the 180 mark. It's never had a problem
  5. #5 Re: is this a normal heat level for the car? look at this
    Cambridge, Ontario Canada
    195 t-stat? Try a swap. Better cool than hot imo.
    2005 E55 - stock
  6. #6 Re: is this a normal heat level for the car? look at this
    Aug 2012
    Is this a faulty thermostat or just not getting hot.
    on the other side. The fan isn't hot enough like it suppose to be.
  7. #7 Re: is this a normal heat level for the car? look at this
    Jan 2013
    Tolono IL
    mines always at the 180 mark
  8. #8 Re: is this a normal heat level for the car? look at this
    Nov 2011
    NY
    Bad t-stat... Replaced it and see what happens. Cheap part n easy fix.
  9. #9 Re: is this a normal heat level for the car? look at this
    thats were mine was at for years, but once i replaced the ect sensor it ****ed everything up and now it reads around 205-210 mark
    SMGPFC Member #10
  10. #10 Re: is this a normal heat level for the car? look at this
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    Bad T-stat. Had the same problem and it threw a SES light.
  11. #11 Re: is this a normal heat level for the car? look at this
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    What is the ECT sensor? Im going to change my t-stat and see what happends
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  12. #12 Re: is this a normal heat level for the car? look at this
    Aug 2012
    Quote Originally Posted by Steven Monteith View Post
    Ses light? Or srs. Cause I have srs light on for first 5 mins.
    Does it have any connection to this that they changed to green coolant before I bought the car that damaged the tstate?
  13. #13 Re: is this a normal heat level for the car? look at this
    St. Louis
    Not likely, but could have air trapped in the cooling system if it wasn't bled properly. Would explain the low heat. Hopefully they flushed the entire system before changing to green.
    And SES is the same as CEL= check engine
    Your SRS light is supplemental restraint system (airbags). Might want to have that one looked into.
  14. #14 Re: is this a normal heat level for the car? look at this
    Jan 2012
    Philadelphia
    I have a 180* T-Stat and my car always runs around that mark, well maybe a little more but under the 1/4 mark for sure usually. But my temperature always fluctuates always did with the stock TStat and the 180*
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. Really... low oil level?
    By dmahlikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2012, 07:55 AM
  3. oil level above than normal?
    By kind153 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2010, 01:37 AM
  4. Next Level STB's
    By 04CompG in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2008, 05:45 PM
  5. Oil Level??
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 08:15 AM
