Thread: GTP Build. Sub 13 Second 300whp goals!
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 21 to 40 of 122
  1. #21
    Basically a direct swap ill post a thread later with info.
    I'd stick w/ a 3.4 first and make sure you don't have any knock and that your pulling good timing when it comes tune time. Knock is what kills majority of our motors.
    04 Comp G.
  2. #22 Re: GTP Build. Sub 13 Second 300whp goals!
    Banned
    Jan 2013
    Colorado
    Quote Originally Posted by Matt Palm View Post
    well a 3.4 on a gen v is the same as a 3.25 on a gen 3. and you need to mod the lim and a plate adapter for the throttle body
    So why can't I run a 3.25 on whatever gen blower is in the car now? And why would I need to modify that stuff just for a bigger throttle body?
  3. #23 Re: GTP Build. Sub 13 Second 300whp goals!
    Florida
    It's not cheaping out on an intake. You are essentially buying a 200 dollar piece of plexiglass or rubber/plastic.
    I've been running homemade intakes for the last 5 years now, no issues.
    If ninja'd one more time I'm going on a rampage.
    04 Comp G.
  5. #25 Re: GTP Build. Sub 13 Second 300whp goals!
    Florida
    The L67 (Gen 3) Throttle body wont bolt directly to a Gen V supercharger. ZZP sells an adapter plate to mate the 2.
  6. #26 Re: GTP Build. Sub 13 Second 300whp goals!
    antioch ill
    if you stick with a gen 3 you can run a 3.25 but i wouldnt right away
  7. #27 Re: GTP Build. Sub 13 Second 300whp goals!
    Banned
    Jan 2013
    Colorado
    What year is the car? A GenV is the newer Superchargers that come on the 04-08 Grand Prix. It retains less heat and is more efficient a common swap. For example if I was to run a 3.6 pulley it'll be just like running a 3.4 on a gen III (name of the prior generations SC)
    I prefer to stick with the basics when it comes to gauges since the Aeroforce can be cycled. Only the major things like of course a WB and oil pressure I keep separate.
    It's a 1999
  8. #28 Re: GTP Build. Sub 13 Second 300whp goals!
    antioch ill
    so you have a gen 3 they went to gen v in 04
  9. #29 Re: GTP Build. Sub 13 Second 300whp goals!
    Florida
    Best option is the Gen V swap. Research it, and you'll see all the benefits to it.
    Start with a larger pulley, and work your way down to the smallest pulley you can run without any knock.
    If you want to maximize your power, consider a full-size intercooler
  10. #30 Re: GTP Build. Sub 13 Second 300whp goals!
    Banned
    Jan 2013
    Colorado
    Ok. Well I haven't heard that it's possible to swap superchargers. How much do newer generation blowers usually go for?
  11. #31 Re: GTP Build. Sub 13 Second 300whp goals!
    antioch ill
    mmm 300 usually
    mmm 300 usually
    This. Unless you find one on eBay or junkyard etc
    04 Comp G.
  13. #33 Re: GTP Build. Sub 13 Second 300whp goals!
    Banned
    Jan 2013
    Colorado
    what do you mean full size intercooler? Do you mean something like this? ZZPerformance - Intercooler #ZZ-FSIC-38
    Correct
    04 Comp G.
  15. #35 Re: GTP Build. Sub 13 Second 300whp goals!
    Wondering why we say dont spend $200 on an intake read this thread http://www.grandprixforums.net/dyno-...ake-33225.html
    This does just as well and costs about 1/4 as much http://www.grandprixforums.net/simpl...res-33351.html
  16. #36 Re: GTP Build. Sub 13 Second 300whp goals!
    Banned
    Jan 2013
    Colorado
    Yeah not gonna spend $1000 bucks on that setup. That's like nearly the price of this entire build. Ok I'll look into other intake options. What about just a throwing a K&N filter in the stock airbox? How good is the stock airbox setup?
  17. #37 Re: GTP Build. Sub 13 Second 300whp goals!
    antioch ill
    you dont want the stock setup just slap a cone on the tb
  18. #38 Re: GTP Build. Sub 13 Second 300whp goals!
    Banned
    Jan 2013
    Colorado
    Alright alright. Is my future setup going to be enough though to break 13 seconds?
  19. #39 Re: GTP Build. Sub 13 Second 300whp goals!
    antioch ill
    um you should be in the 13 for sure
  20. #40 Re: GTP Build. Sub 13 Second 300whp goals!
    Banned
    Jan 2013
    Colorado
    and 300whp?
  1. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  2. 300whp??
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2010, 11:27 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. What about a smaller build to 300WHP
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2008, 02:01 PM
  5. Goals for my gtp this summer
    Last Post: 02-16-2008, 02:24 PM
