Thread: please help, car wont start
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 please help, car wont start
    Aug 2012
    Tukwila, Washington, United States
    hi guys. today i took the car to do some stings and i got back to the parking lot and car was kinda shaking.
    i turned it off and back on. and still shaking.
    i parked it i looked under the hood and the radiator hose was FLAT . like sucked in . no air.
    i opened the radiator cap and allowed air in and it went back to normal. i notices that coolant is almost gone and before that it was full all the way.
    i added some water and tried to turn on the car and it didn't turn on.
    making some loud noises.
    its not battery. i think i even saw a service engine for a second.
    please help im stuck in a different state.
    car details on signature.
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: please help, car wont start
    Oct 2012
    Ipperwash Ontario
    Check your oil and if its light brown and foamy then blew a head gasket and are in trouble
  3. #3 Re: please help, car wont start
    Does it even try to fire?
    Or does the starter just crank and crank.
  4. #4 Re: please help, car wont start
    Aug 2012
    just crank
  5. #5 Re: please help, car wont start
    Omaha, NE
    Was it making a knocking noise before it died?
    Did you notice a wet trail behind you?
  6. #6 Re: please help, car wont start
    Aug 2012
    thats a video of the sound when i start the car.
    there no oil coolant mixture.
    hose was sucked in flat. car shaked. turned off turned on dead.
  7. #7 Re: please help, car wont start
    Aug 2012
    Please help. I'm stuck far away from home.
  8. #8 Re: please help, car wont start
    Oct 2012
    Ipperwash Ontario
    Well u need to get your car scanned to find out what code is there
  9. #9 Re: please help, car wont start
    Sounds like the starter is grinding on the flex plate or inside itself.
  10. #10 Re: please help, car wont start
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Give the starter a good whack with a BFH.
    1997 Red GTP 182000 miles stock
  11. #11 Re: please help, car wont start
    Dec 2012
    Where 4T65E's were born
    The engine doesn't sound like it's turning over, like the post above, it sounds like it's grinding. It's most likely the starter that's at fault. As with the radiator hose being sucked in, I have seen this before. It was when somebody mixed dex cool and regular green coolant. I flushed the system and replaced the radiator cap and thermostat and that solved the problem. I believe it was the radiator cap that was letting too much pressure out. Then when it cooled back down, the system would go into negative pressure. The tube from the radiator cap to the overflow tank was plugged as well.
    Sold.
  12. #12 Re: please help, car wont start
    Aug 2012
    it was sucked when i was still driving. a scond before i parked i felt it shaking. and i got it into the parking lot. do you think theres hope for the engine?
    the car has 216k on it but it was running smooth like a new car. no noise or anything.
    i must say i saw some white smoke coming out of the exhaust but maybe maybe its cz its cold. or maybe gasket going bad.
  13. #13 Re: please help, car wont start
    Nov 2011
    Florida
    Sounds like a dead stop on the flywheel to me. Get it turned off that spot and it should at least turn over.
  14. #14 Re: please help, car wont start
    Omaha, NE
    Does the oil look like it should or is coolant in it? That's usally what causes white smoke.
    My guess is that there's coolant in it, which killed your rod bearings. In that case you would need a complete overhaul or new engine.
    Best case scenario, you could replace the head gaskets, but my guess is that chance has come and gone.
  15. #15 Re: please help, car wont start
    Aug 2012
    Oil color was normal. No oil mix with coolant.
  16. #16 Re: please help, car wont start
    Aug 2012
    heres 2 videos of the engine. the first one looks like the engine is trying to move. but second one nothing moves
    please watch
  17. #17 Re: please help, car wont start
    Aug 2012
  18. #18 Re: please help, car wont start
    Your started is either broken or binding up.
    Or the motor is locked up. Try and turn the motor over by hand, maybe even pull a few spark plugs to make sure its not hydrolocked.
  19. #19 Re: please help, car wont start
    Aug 2012
    Is it possible that the engine died? Is this how dead engine looks like?
  20. #20 Re: please help, car wont start
    Omaha, NE
    Dead engines look like good engines unless you throw a chunk of rod through the block...
    Pull the starter and try to spin the motor by hand. Take the starter to advance or wherever and have it tested. Change the oil and check for metal flake. If all that checks out, do a compression test.
  1. 04 gtp wont start
    By BlackCompg04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2012, 08:53 AM
  2. car wont start
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2012, 09:45 AM
  3. 98 Gtp wont start
    By qwiver1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 11:15 PM
  4. car wont start need help
    By 2001goldGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2011, 09:02 AM
  5. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
