Thread: emissons coming up, got a question
Results 1 to 17 of 17
  1. #1 emissons coming up, got a question
    Yoga city
    well hello to everyone lol Gotta ask, My car has an abs light on and prolly not gonna be able to get it fixed. emissions testing and saftey testing are 2 different things correct? As long as all my sensors read ready or some shiat like that i should be fine? Im in illinois so if that helps any.
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by JTeske88 View Post
    I would assume that emissions and safety are two things. Emissions makes sure u have no exhaust leaks and that u have the appropriate things like mufflers CAT and all. Safety I'm not quite forsure what they look for except maybe airbags seatbelts headlights brake lights etc. Somebody with more experience should chime in hopefully this helps a little
    Sent from my DROID RAZR using Tapatalk 2
  3. #3 Re: emissons coming up, got a question
    Yoga city
    yeah, i read about it a bit and cant seem to get a good answer, if it fails im screwed, cause my abs thing is now out of my reach. ive done all i can with out haveing a tech2 either way come tax time cars fobs and all will be working
    Jun 2012
    Ur abs lights on?
  5. #5 Re: emissons coming up, got a question
    Yoga city
    yup for sure is and all i get out of abs side is u1301, tracked down wires and all ohm out correctly and such per gm manual
    Jun 2012
    Did ya just replace the hub to see if that fixes it
  7. #7 Re: emissons coming up, got a question
    Yoga city
    replace the hub? i dont have a code for a hub by any means
    Jun 2012
    And is built into the hubs isn't it?
  9. #9 Re: emissons coming up, got a question
    Yoga city
    not as in teh speed senseing wires, the class 2 data
  10. #10 Re: emissons coming up, got a question
    Yoga city
    the class 2 data, it the one that sends the wake up signals to everything. this is what leads me to believe the abs module is not getting the wake up message, and also believe this is why teh fob reciever doesnt get it ether, its all tied together. Just blows my mind that sometimes when its cold it acts fine.
  11. #11 Re: emissons coming up, got a question
    Texas
    ABS light will not cause a car to fail inspection...... At least in Texas. You should be able to go to your states DMV site and look up that info. Or take the lazy way out and just call a place that does inspection and ask them.
    85 Corvette
    01 TA
    03 Z06
  12. #12 Re: emissons coming up, got a question
    Yoga city
    yeah i tried calling with the last gp, no help with them, im gona go in friday and have in checked. if i fail for that dumb stuff i actually have until march something to get it fixed by the deadline
  13. #13 Re: emissons coming up, got a question
    Johnstown, NY
    My cavalier, grand am, grand prix and accord all passed inspection with an abs and traction control lights. If you have an obd2 plug in test, you'll pass as long as the check engine light is off. The safety inspection pretty much makes sure the brake pads and rotors are good, good tire tread, ball joints good,etc. It's a visual inspection. Emissions is a plug in scanner tool and or rolling sniffer.
    Again, the plug in scanner only reads for engine codes, and doesn't see if the abs lights on.
    I live in ny, the inspection standards here are more strict than most states.
  14. #14 Re: emissons coming up, got a question
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    This may help, but i live in the most strict emission state, California.... and i havent failed an emission test yet on my LS. ABS has nothing to do with emissions. For the record though, the cause of that ABS light is mostly bc you have a open circuit, a short or low voltage to one or all four ABS sensors. you should pass emissions though...
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  15. #15 Re: emissons coming up, got a question
    my car passed in NJ with the abs/trac off light on, and the air bag light on lol.
    if the check engine light is on its a instant fail here.( they have a huge sign hanging lol ) everything else slides here.
    only one thing to do, go and see what happens, if you fail most states give you a month to get it fixed and reinspected.
  16. #16 Re: emissons coming up, got a question
    Neighbors failed for a fuel level code.
  17. #17 Re: emissons coming up, got a question
    Johnstown, NY
    But that was probably triggering a cel. Abs isn't even required on cars, so I can't see why if the abs is turned off it wouldn't pass.
  1. How my 06' GT is coming along
    By DreamerGT in forum Members Rides
    Last Post: 06-02-2014, 06:30 PM
  2. It's coming!
    By Toasty in forum Visual/Body Modifications
    Last Post: 11-01-2009, 03:44 PM
  3. Did they see me coming?
    By collforone in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 01:45 AM
  4. Key not coming out
    By Bruteforce72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 04:19 PM
  5. Coming soon to an Autozone near you...
    By DanGTP in forum Off Topic Discussion
    Last Post: 07-22-2008, 08:14 PM
