Thread: to fix or not to fix?
Results 1 to 16 of 16
  1. #1 to fix or not to fix?
    SE Level Member Adam D's Avatar
    Jan 2013
    grand rapids mi
    So i picked up a 98 gtp a couole days ago with some issues. Mainly ones i had noticed where a little exterior rust smashed front bumper(i already got a new one) and it clearly needed a LIM well upon further inspection of the car the oil seepage i had noticed seems worst then i had hoped not horrible. Only leaving a few drops in the garage seems to be coming from the oil pan. The worst part though that i didnt notice when purchasing was the rockers are almost gone. Bright side is the tranny seems pretty good and i was told it was replaced around 70k ago. Anyway i think i could probably dump the car or definatley part it out and make some money on it. But i was wondering what you guys thought should i just do the LIM drive it til it blows and use it for a parts car or is a motor with 230k on it not worth the few hundred bucks when its leaking oil too. Or do i find a junkyard motor put it in and drive the wheels off this thing.
    Sent from my SPH-L710 using Tapatalk 2
  2. #2 Re: to fix or not to fix?
    antioch ill
    you sure its not just the crappy gasket leaking on the lim
    Fix the lim. Don't worry about the the minor oil pan leak until it gets worse. Drive it to the wheels fall off. Or drive it for awhile and sell it. Way I see it right now is that you got a perfect DD no sense it parting it out until something major goes wrong and its not worth fixing,
    04 Comp G.
    Jan 2013
    grand rapids mi
    Quote Originally Posted by Matt Palm View Post
    You mean leaking the oil? I know the lim is bad and from the looks of underneath the car the oil pan gasket is bad too.
    Jan 2013
    grand rapids mi
    I think im leaning that way. Just need to hear that im not insane for putting the money into it
  6. #6 Re: to fix or not to fix?
    Sep 2011
    Copperas Cove, TEXAS
    My 98 is slowly beginning to come around, the right rocker is almost gone to the point it sh1ts rust in my driveway. I was thinking the same thing fix a little then trade/ dump it. Now after all the work and effort, it has grown on me and as for performance it's great.
    Grand Prix are like kids, they drive you nuts, then one day surprise you and you realize why you kept them.
  7. #7 Re: to fix or not to fix?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    It's really up to you if you like the car or not, rockers suck but oh we'll you don't notice it by looking at it, don't the lim and just drive it, 230k miles really isn't a lot for a 3800
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  8. #8 Re: to fix or not to fix?
    Just fix the lim and drive it. I haven't had to put much into my car. I'm going to drive it until it rusts in half but it'll be cammed and ic by that time.
  9. #9 Re: to fix or not to fix?
    Jan 2013
    michigan
    hope you didn't pay to much for it because i seen a 99' on craigslist today in kalamazoo for 1500 needs a new steering rack but the engine only has 149,000. as for your car just fix it and make it your daily driver.
  10. #10 Re: to fix or not to fix?
    gtp?^^
  11. #11 Re: to fix or not to fix?
    Oct 2011
    Michigan
    Quote Originally Posted by locuno1 View Post
    You don't know what's actually wrong with that cars it's probably a pos for that cheap
    Jan 2013
    grand rapids mi
    I picked it up for 700 bucks the only reason i payed that much honestly is it has brand new goodyears on it. I noticed everything accept that rocker rust when i bought it.
  13. #13 Re: to fix or not to fix?
    Oct 2011
    Michigan
    How bad is the lim like milky coolant or you just wanna do it to prevent failure? Honestly for $700 I'd just drive it as is a barley keep it on the road it's worth $500 in scrap lol
  14. #14 Re: to fix or not to fix?
    Jan 2013
    michigan
    you could always fix it and flip it for some quick cash.
    Jan 2013
    grand rapids mi
    That was actually why i got it in the first place. But i always wanted one of these cars so i decided to f with it and see what happens. The tranny is solid so i figure if i fix the lim i can run it for a while and play with it with some bolt ons. and the lim is toast i took it apart today and it is way worst then i thought
    Jan 2013
    grand rapids mi
    I started a new thread on what mods to do while i have it apart
fix
