Thread: Instrument panel cowel thingy?
Results 1 to 15 of 15
  1. #1 Instrument panel cowel thingy?
    Jan 2013
    Charleston, SC
    Hey dudes. Bought a 2006 GP Base that came with cracked windshield. Before I get it replaced, I wanted to get ahold of the plastic piece that sits right in front of the instrument panel but under the windshield wipers (inside). This piece also houses the theft deterrent light and the solar sensor too. Mine's is cracked all to hell. What the heck is this piece called and where can I get one cheap? I wanna avoid the stealership of course. Anyone ever replaced this part?
  2. #2 Re: Instrument panel cowel thingy?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Go to a junk yard find one and pull it
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
    I live here. DirtDog's Avatar
    Jun 2012
    Heck there was one in great condition at a junk yard I went to last week. I'm planning to go make another trip
    Sent from my DROID RAZR using Tapatalk 2
  4. #4 Re: Instrument panel cowel thingy?
    Jan 2013
    Charleston, SC
    No crap? A junk yard? Who would a thunk. Got an LKQ here but nothing as new as my car there. What's the damn thing called.
    Quote Originally Posted by asite57 View Post
    Jun 2012
    The one I use is called a pick n pull. It's in Wellington nc.
  6. #6 Re: Instrument panel cowel thingy?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    LKQ are great, got two of them here.
    1997 Red GTP 182000 miles stock
  7. #7 Re: Instrument panel cowel thingy?
    Nov 2012
    Madison
    Quote Originally Posted by MePrix View Post
    2006 PONTIAC GRAND PRIX Parts - GM Parts Direct
    Check that page, believe its what your talking about. Junkyard most likely would save you some coin.
  8. #8 Re: Instrument panel cowel thingy?
    Jan 2013
    Charleston, SC
    Thanks for the link spazzzzz. That's the one. Upper trim panel. W/O HUD is more $$$. That's redonkulous for a piece of GM plastic. What a ripoff.
    Any other cars that might have the same trim panel besides the GP? I understand we have some close cousins of the GP in the GM family.
  9. #9 Re: Instrument panel cowel thingy?
    Jan 2013
    Charleston, SC
    Another pick a part joint just opened up the road, but you don't know what vehicles they have in stock. LKQ lists new arrivals on their website. I'm trying to upkeep a '99 Infiniti i30, a 2002 4 runner and now this car, so knowing what just arrived on the yard really helps.
    Quote Originally Posted by GTP in RTP View Post
  10. #10 Re: Instrument panel cowel thingy?
    Nov 2012
    Madison
    If its not all in pieces, or you can't get one easy enough, maybe you could try some plastic epoxy.
    Just sand everything smooth and paint it.
  11. #11 Re: Instrument panel cowel thingy?
    Jan 2013
    Charleston, SC
    It's in two chunks, but I could epoxy. Amazingly enough, there's an 05 on Craigslist and it has a photo of the dash. Big *ss crack in the exact same place. What does it take to get that panel out of there?
  12. #12 Re: Instrument panel cowel thingy?
    Nov 2012
    Madison
    HUD - Heads Up Display for Pontiac Grand Prix 2004 Repair Instructions
    The link is for the HUD repair but explains the necessary steps, you'll see.
  13. #13 Re: Instrument panel cowel thingy?
    Jan 2013
    Charleston, SC
    Thanks again spazzz. After I saw this I'm rethinking this repair. I might end up living with it for a while. I was hoping I could get to it easily with the windshield out. Doesn't look like it will be as easy as I had hoped.
  14. #14 Re: Instrument panel cowel thingy?
    Nov 2012
    Madison
    Yo Me, it's super easy to get that out. I used a painters 5- in- 1 knife for most of the panels to get them started until I could get my fingers in there. Be careful of the ignition ring, its the only piece that sorta broke. It has 4 tabs that hold it in and my dumbass broke two of them. I just used some black RTV to hold it in place. The sensors on that cowl thingy have limited room to remove/install because of the wire length. But yeah, you can do it.
  15. #15 Re: Instrument panel cowel thingy?
    Jan 2013
    Charleston, SC
    Started pulling this out and it is a ****tch. Theres some ultra sticky foam strip back there that won't let go. I will not let it win though. Now if I can find a cowl at the junkyard, installation looks to be alot easier.
  1. Instrument Panel Out!!!!!
    By Torell10 in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2012, 01:53 PM
  2. Instrument Panel lights help
    By BlackGT1 in forum Audio, Security & Visual Electronics
    Last Post: 10-08-2011, 08:29 AM
  3. 04+ Instrument panel in 97-03
    By nebgrandprix in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2011, 04:11 PM
  4. Instrument Panel
    By iceman977th in forum Visual/Body Modifications
    Last Post: 12-23-2010, 04:04 AM
  5. White Instrument Panel
    By cboth686 in forum Visual/Body Modifications
    Last Post: 04-12-2009, 08:52 PM
