Thread: Is it safe
Results 1 to 12 of 12
  1. #1 Is it safe
    SE Level Member Lil larry's Avatar
    Nov 2012
    Elkview, west virginia
    Is it safe to start modding my car at 182k mi. I'm planning on doing full exhaust and intake
  2. #2 Re: Is it safe
    If you only plan exhaust and intake..yes.. you'll be fine.
    Hell.. I decided to cam and Gen V mine at 186K
  3. #3 Re: Is it safe
    you also picked one of the most expensive and useless things to do (full exhaust). headers are a plus in anyones book. the catback is a literal waste of money.
  4. #4 Re: Is it safe
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Make your own intake.
    Full exhaust? i hope your talking about headers. A catback is pointless, it flows just fine.
    Make sure all maintenance is in check first such as plugs, wires, LIM, fuel filter, new vac lines, oil change, filter change, Blah blah blah, you get the point.
    Yes your car will be fine.
    Read this:
    http://www.grandprixforums.net/safel...0-a-67580.html
    Edit: Looks like Bio & I are on the same page about the exhaust.
  5. #5 Re: Is it safe
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Bolt on flow mods are are good idea no matter how high the miles.
    Cat back is not a flow mod, its an appearance and sound mod. (Unless your pushing 400+ whp)
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  6. #6 Re: Is it safe
    Nov 2012
    This will just be the beginning of my plans I also plan on top swap and a nic cam,heads and so forth later but I will need a overhaul by then. I was just wonder if it was safe to do these bolt ons at this high of mileage I have not had good luck modding a higher mileage motor. I'm planning on the wizard intake and slp headers and catback.
  7. #7 Re: Is it safe
    Those mods will be fine on the motor.
  8. #8 Re: Is it safe
    Jan 2013
    michigan
    182k isn't really high miles on a 3.8
  9. #9 Re: Is it safe
    Nov 2012
    Thanks for all the info guys hopfully ill be able to start a build thread soon
  10. #10 Re: Is it safe
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    He might have to do a full exhaust if he's in the north, mines was more rust then pipe lol JY were no help either
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  11. #11 Re: Is it safe
    Check out my sig those miles are fine
  12. #12 Re: Is it safe
    Oct 2011
    Michigan
    Yeah I'm at 180k miles when you mod it's like having a hole new car lol everything's been changed
  1. is it safe too......................
    By GTPAIELLO in forum General Tech Discussion
    Last Post: 12-05-2012, 10:52 AM
  2. Is it safe?
    By 95concours in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2012, 11:06 PM
  3. Safe to Run 3.0 Again?
    By Hixc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2011, 10:14 PM
  4. safe??
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 01:58 AM
  5. Will this be safe?
    By Silver GTP in forum General Tech Discussion
    Last Post: 06-08-2010, 01:07 PM
