Thread: 00 olds silhouette L67 swap
Results 1 to 10 of 10
  1. #1 00 olds silhouette L67 swap
    I might be picking up a 00 olds silhouette tom with a bad trans and was thinking since i have the parts in the garage an s1x cammed l67 minivan would be a lot of fun. Anyone know how hard the wiring would be? I have a harness from a 00 gtp I can use.
  2. #2 Re: 00 olds silhouette L67 swap
    Aug 2011
    'Merica
    i don't remember how it hard it would be, but you let me know how it works out for you. We have a venture with 200K and around 100k on the 3.4. Thinking this would be a great idea once the engine decides to eat itself. Lots of pics. Too bad you don't have the cradle for the GTP, because I think it is a straight swap between the 2.
  3. #3 Re: 00 olds silhouette L67 swap
    Pretty sure the Subframe from the van works fine.
  4. #4 Re: 00 olds silhouette L67 swap
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    you have to massage the firewall where the alternator area is and your better off using a different tb like a ls1 as you wont have to worry about interfearig with the brake master cylinder,
    for an olds you will have to run a regal harness as they are more compatable with the interior harness, and you will have to shange only a few wires then.
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  5. #5 Re: 00 olds silhouette L67 swap
    Aug 2011
    'Merica
    Kuntzie you had a turbo L67 Montana didn't you?
  6. #6 Re: 00 olds silhouette L67 swap
    Feb 2010
    turbo l26 yes
  7. #7 Re: 00 olds silhouette L67 swap
    Aug 2011
    'Merica
    nice
  8. #8 Re: 00 olds silhouette L67 swap
    Quote Originally Posted by kuntzie View Post
    Regal l36 or l67? Is it pretty much a plug in then?
    I went and looked at it today and the pump seal is bad and pouring trans fluid everywhere so I might just throw a trans in it and drive it to make sure everything else works in it before I attempt the swap.
  9. #9 Re: 00 olds silhouette L67 swap
    Feb 2010
    its pretty close to plug and play, just look at the large connector near the drivers strut tower and make sure you get the harnes that looks like the harness n your van as it sits ( there is either one o 2 wires ~8 gage in a single harness that goes to the inside, some have yellow, yellow black, red red, red black, red yellow ect, just make sure its the same as the van like i said
  10. #10 Re: 00 olds silhouette L67 swap
    Bettendorf, IA
    how did this turn up? i'm thinking about doing this to a 2004 silhouette, a Final 500 van. Thoughts?
  1. 1997 Olds Cutlass Supreme 3800 swap
    By Sven the Sexman in forum General Tech Discussion
    Last Post: 12-06-2012, 11:13 PM
  2. 98 Olds Intrigue Stalling / Missing
    By Captain Bravo in forum Engine
    Last Post: 06-07-2011, 06:06 PM
  3. tuning for olds intrigue
    By nascartech in forum PCM Tuning
    Last Post: 03-22-2011, 10:27 PM
  4. olds intrigue
    By nascartech in forum Off Topic Discussion
    Last Post: 03-19-2011, 11:27 PM
  5. Wanting ‘72 Olds Cutlass
    By AlphaBetaBase in forum Off Topic Discussion
    Last Post: 01-17-2008, 10:26 PM
