Thread: No Heat
Results 1 to 7 of 7
  1. #1 No Heat
    Jan 2013
    Mascoutah Illinois
    I have an 2006 Grand Prix, I no longer get heat in the car. I have replaced the drivers side actuator motor. The lines to the heater core are hot on both lines. What else should or could I look at?
  2. #2 Re: No Heat
    May 2008
    Schuyler, NE
    Is your blower motor working? Is air coming out of the vents?
  3. #3 Re: No Heat
    Jan 2013
    Mascoutah Illinois
    yes the blower motor is working, I can get cold air to blow out of all the vents.
  4. #4 Re: No Heat
    I'm thinking one of the other blend doors is not working because you have heat coming out of both heater core hoses.
  5. #5 Re: No Heat
    Jan 2013
    Mascoutah Illinois
    I replaced the drivers side and still only have cold. i do have dual climate control, is the passenger side just as important?
  6. #6 Re: No Heat
    Jan 2013
    Mascoutah Illinois
    replaced both blend door actuators and still cant get any heat.What elseshould I look at?
  7. #7 Re: No Heat
    by chance when you had the actuator off, did you try to turn the knob it sits on, turn it one way is cold, the other is hot. if its sticky or wont move, the actuator wont turn it.
    you can also take the glove box off, and change the temp while holding your finger on the part that moves to see if its moving at all if you dont want to just take it off.
    if you do take it off, leave it plugged in, then work the temp up and then down, see if it moves. if it dont move you may have a blown fuse or bad climate control.
    whats the outside temp reading, is it accurate? or way off, the temp sensor can also throw off your heat.
  1. Need some serious help no heat!
    By shawnschuldt in forum General Tech Discussion
    Last Post: 02-25-2012, 09:06 AM
  2. Heat & A/C Fan
    By rcme in forum General Tech Discussion
    Last Post: 11-13-2011, 09:08 AM
  3. Heat
    By mongoclark in forum General Tech Discussion
    Last Post: 02-05-2010, 09:13 PM
  4. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  5. How much does heat......
    By GTP4 in forum PCM Tuning
    Last Post: 05-08-2009, 11:54 AM
