Thread: back fire now ticking sound..?
Results 1 to 7 of 7
  1. #1 back fire now ticking sound..?
    Nov 2012
    Ohio
    Since it started getting cold out, my 00 GP SE 3100 has had trouble turning over. Yesterday I started it and it back fired, now there is a ticking sound. I know its not a lifter tick or rod knock (Those sound im familiar with), this sounds like a watch ticking sped up. When i rev the motor it goes away, could this be the dreded spider injector tick?
  2. #2 Re: back fire now ticking sound..?
    Spider injector? I don't believe you have the spider system that a 4.3L has.
  3. #3 Re: back fire now ticking sound..?
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    I'd check for an exhaust leak
    97 Bonneville SE Not so much a 97 anymore
  4. #4 Re: back fire now ticking sound..?
    Nov 2012
    Ohio
    The cover piece says 3100 Sfi, thought it meant spider fuel injected?
    I did have a look at my manifold, there seems to be a hair gap. I tightened down the bolts and now i just have to wait until it is 30 degrees or less out to see if it back fires again. Since it only does it when its all cold out.
  5. #5 Re: back fire now ticking sound..?
    Dec 2012
    Where 4T65E's were born
    I recently had a ticking noise that came when the engine was cold. I knew it wasn't lifters or a rod knock by the sound. It ended up being the Vapor Canister Purge Valve, and was normal. I have the 3.8, but it's probably in the same area. Here's a picture of mine:
    Sold.
  6. #6 Re: back fire now ticking sound..?
    Nov 2012
    Ohio
    Mine was more dominate sounding from the driver side of the motor but that could be something to look into as well. I did notice it didnt make that tick sound when i started it tonight though.
  7. #7 Re: back fire now ticking sound..?
    Sequential fuel injection. It's probably an exhaust manifold leak.
  1. Straight pipes sound bad, loud ticking when accelerating
    By 2000 Grand Prix GT Blue in forum General Tech Discussion
    Last Post: 04-12-2012, 12:05 AM
  2. ticking sound
    By devinbajus in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2012, 03:27 PM
  3. Any ideas on a ticking sound?
    By Drew86maro in forum Engine
    Last Post: 09-30-2010, 11:25 PM
  4. Engine ticking sound
    By zildjian102 in forum General Tech Discussion
    Last Post: 07-30-2010, 12:24 AM
  5. Ticking/knocking sound in engine compartment
    By 200GpGt in forum General Tech Discussion
    Last Post: 04-17-2010, 03:54 PM
