Thread: replaced head gasket and now im stumped !
Results 1 to 6 of 6
  1. #1 replaced head gasket and now im stumped !
    Dec 2012
    Camden TN
    hello im new here ,but figured i would see if anybody could help me . I have a 02 grand prix with the 3.1 im it ,and it blew a head gasket early this week ! well i bought the head set ,and tore it down . took the head to be checked cleaned and surfaced . it was fine . so i put it all back together following all tourque specs and what not . When i was done the car fired rite up ,but has a terible miss to it ! i double checked all my plug wires and they are correct i have new plugs . i went back and double checked all my wires and it dont appear that i missed any of them . so do any of you guys have an idea ?
  2. #2 Re: replaced head gasket and now im stumped !
    Pennsylvania
    Scan for codes.
    The engine has an audible/visual miss? Um, maybe make sure the wires all go to the right spot. Make sure injectors are all plugged in.
  3. #3 Re: replaced head gasket and now im stumped !
    Dec 2012
    Camden TN
    im going to hook scanner to it in the morning and yes you can hear and see the miss i did double check all the wires goin to do that once more also . im not sure about the injectors though have not double checked them yet . another thing i for got to mention it has this really really bad stink bomb smell now that it didnt have before . you no like rotten eggs , when i started it inside the shop it made my eyes water in a matter of seconds 1 it wasnt doing that before i no for a fact . when i was checking for the haed gasket i ran it for awile in the shop and there was no smell like that
  4. #4 Re: replaced head gasket and now im stumped !
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    rotten egg smell is a bad catalytic converter I believe. Might wanna check it out, if it's clogged it could cause a misfire
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  5. #5 Re: replaced head gasket and now im stumped !
    Take your front o2 sensor out and see if the miss goes away
  6. #6 Re: replaced head gasket and now im stumped !
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    did you put the pushrods back in correctly
    COMP G
  1. Head gasket and head crack questions.
    By deib in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 03:50 PM
  2. cracked head blown head gasket or just done??
    By roytoy70 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2012, 10:40 PM
  3. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  4. Replaced EGR valve and gasket, SES still on
    By GTLGDP in forum General Tech Discussion
    Last Post: 03-08-2012, 11:08 AM
  5. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
