Thread: Starting issue
Results 1 to 2 of 2
  1. #1 Starting issue
    Dec 2012
    Missouri
    I have this Pontiac Grand Prix gtp. It has less than 50000 miles. Supercharged. It will fire right up and run like a bad ass. Then if you turn it off and back over, it may or may not turn the fuel pump on. Doesn't throw any codes either. Any suggestions?
  2. #2 Re: Starting issue
    SE Level Member volvo92906's Avatar
    Nov 2012
    Ohio
    Find out if youre getting power to the fuel pump when this happens. If you are, then the pump is bad. If you arent, something is wrong. Then you work your way to the relay and same thing, check for power. If you do, it is between relay and pump. If you dont, then you have a problem from the battery to the relay.
    ASE Master Medium Heavy Truck
    ASE Master Automotive
  1. Please someone help me out here, starting issue.
    By Brickie in forum General Tech Discussion
    Last Post: 01-12-2012, 12:10 AM
  2. Please someone help me out here, starting issue.
    By Brickie in forum Off Topic Discussion
    Last Post: 01-09-2012, 12:30 PM
  3. Starting issue
    By GTP Ryan in forum General Tech Discussion
    Last Post: 08-28-2011, 02:55 AM
  4. 97 Gtp starting issue
    By DukesGTP in forum Off Topic Discussion
    Last Post: 10-29-2010, 06:35 PM
  5. Starting issue
    By MuTaLiZeD in forum General Tech Discussion
    Last Post: 07-31-2009, 01:03 AM
