Thread: thermostats
Results 1 to 11 of 11
  1. #1 thermostats
    May 2011
    winnipeg
    has anybody tried using a 205 degree thermostat in an 04 gp with the series 3 3800 ? It seems like the 195 never gets to proper temp.
  2. #2 Re: thermostats
    If that's the case, you just need a working 195.
    Chances are, what you're seeing are the very lax fan settings.
  3. #3 Re: thermostats
    May 2011
    winnipeg
    where should the needle on the gauge be for 195 degree. I have tried 2 new stant superstats so far
  4. #4 Re: thermostats
    No clue on the 04+, never owned one.
    Wait for someone else to respond or search for it.
  5. #5 Re: thermostats
    I believe right in the middle is about 190ish.
  6. #6 Re: thermostats
    May 2011
    winnipeg
    it used to run right in the middle for the first few years but after I changed the original stat i could never get it back up there , even with an oem replacement
  7. #7 Re: thermostats
    I live here. TLSheff's Avatar
    The grand prixs from 97-08 all use the same thermostat, NA, Supercharged, 5.3L GXPs, all use the same 195* thermostat. Figuring when it opens it will still run a little hotter, most will probably run about 200-210* depending on the car and outside temps and driving conditions. GM# 24505924 - Retail $18.20 from a dealership, may be more or less being in Canada.
    For my car idle in a Texas/Ok summer in traffic on a 105*+ day the temp would see around 220* with the factory thermostat. This is why I dropped to a 180*. That being said, Winnipeg, CA would be much colder most of the year so you may be fine with just a factory 195* thermo, but I do NOT believe they make a compatible hotter one. She is just gonna run cool up there.
    Replace the thermostat, flush the coolant and replace and see if she runs warmer sooner, you may just have to allow more time to warm up to operating temps.
  8. #8 Re: thermostats
    Pennsylvania
    Think it ought to ride just above the quarter mark. Honestly, I can't imagine what would make the engine too cold, except a thermostat being stuck open.
  9. #9 Re: thermostats
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Quote Originally Posted by SlowNA06 View Post
    That is EXACTLY where mine sits if im at speed. Torque reads 188.6 or 190.2 at this point.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  10. #10 Re: thermostats
    Sep 2012
    Bangor, ME
    From experience and using Torque, these are all approximate starting at the quarter mark, nor is the movement in equal increments. The cold line is 140. For those of us up north, i generally do not turn on the heat until the gauge reaches this mark. It allows the engine to warm a little quicker and get better heat out of it.
    Quarter Mark- 179
    185
    194
    203
    Half Mark- 210
    221
    230-Highest Ive been, My water pump failed and I shut the car off at this point
    My car has a 180 stat (from previous owner, i might change back to 195) and when cruising i get to about 186-192, between the first and second line past the quarter mark.
    It freaked me out when i first got the car and saw the needle go past the middle line when i was idling. Then I thought back to the cars my parents owned. the 94 Olds 88 went to 220, middle mark was 200 on that car. The 01 Buick Century also went one line past center at idle. All that time I thought there was something wrong with the olds because it went past the 200 line,
    GOD BLESS...
  11. #11 Re: thermostats
    May 2011
    winnipeg
    Thanks for all the input, I guess it is where it should be and I'm just too fussy. I put in another stant superstat and now it's just take what you get .
  1. Swapped Thermostats
    By dhall9 in forum General Tech Discussion
    Last Post: 07-19-2009, 03:56 PM
  2. Hypertech PowerStat Thermostats
    By cojo in forum General Tech Discussion
    Last Post: 04-26-2009, 08:44 PM
  3. Thermostats !!!
    By DC1263 in forum General Tech Discussion
    Last Post: 02-26-2009, 10:11 PM
