Thread: check engine light
Results 1 to 6 of 6
  1. #1 check engine light
    Dec 2012
    canada
    hey! i just bought a 01 grandprix gt and the check engine light came on. what do you think it is? its running fine. also how high does the engine temp gauge sit at?
  2. #2 Re: check engine light
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    go to a local parts store and have them scan it for free. and it depends on what thermostat you have.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  3. #3 Re: check engine light
    Donating Users mystic231's Avatar
    Michigan
    The batteries on my crystal ball are dead
    If the car is running fine it's probably emission control related and may even go away on it's own. Have an auto parts store check it for free or purchase a Kiwi PLX Devices unit & the Torque app for your Android phone and you can check it yourself.
    If it's the stock T-stat iit's set for 195 degrees F; not sure what that is in degrees C.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  4. #4 Re: check engine light
    Sep 2011
    Copperas Cove, TEXAS
    Gotta love that Torque App., reads and clears codes and you can monitor the engine with it.
  5. #5 Re: check engine light
    I know...it's time to get that code read. Seriously..with the info you gave us.. it could be anything at all.
  6. #6 Re: check engine light
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Quote Originally Posted by Grandprixgt001 View Post
    I think it's a light on the dash. AutoZone will scan your car for free and tell you the code.
  1. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  2. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  3. check engine light goes on and off!!
    By stanggreg90 in forum General Tech Discussion
    Last Post: 06-19-2009, 12:37 AM
  4. check engine light
    By kiljoy06 in forum General Tech Discussion
    Last Post: 01-11-2009, 07:27 AM
  5. check engine light
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2008, 08:48 PM
