Thread: Brown in radiator fluid
Results 1 to 4 of 4
  1. #1 Brown in radiator fluid
    SE Level Member Bessesen2's Avatar
    Jul 2012
    Livonia,MI
    I looked in my radiator and I noticed brown heavier chunks inside. (The car still has orange dexcool also). To my knowledge, it could be stop leak? Buy either way I plan on doing a system flush and put unviversal Prestone in the system
    1999 Grand Prix GTP. 157xxx miles and climbing everyday.
  2. #2 Re: Brown in radiator fluid
    Could be stop leak or the dexcool gelling up. Do a coolant flush.
  3. #3 Re: Brown in radiator fluid
    when dex coolant has air in the system, it boogers up. like snot balls lol
    flush the engine and rad, then add green coolant.
  4. #4 Re: Brown in radiator fluid
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    Flush that system like scotty said. DEX COOL has an organic compound that gets destroyed when tap water is added to it, basically ruining the coolant.
  1. Brown Fluid = Trouble?
    By Russosaur in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-25-2012, 04:06 PM
  2. harsh shift + brown fluid.. problem?
    By kind153 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-20-2012, 12:46 AM
  3. Brown trans fluid, drain and refill?
    By KZOO3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-02-2011, 07:28 PM
  4. Transmission fluid leaking into radiator.
    By Fatboy58 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2010, 10:24 AM
  5. Brown Sludge under radiator cap
    By streetsmart in forum General Tech Discussion
    Last Post: 03-22-2009, 01:16 PM
