Thread: Head Gasket
Results 1 to 13 of 13
  1. #1 Head Gasket
    Aug 2012
    toronto
    Took it to my mechanic today.He said the head gasket tubes are almost worn out,and need replacing.
    I cant afford that for 2 weeks.
    I only use the car locally,and it rarely smokes during driving.
    How risky is it to drive it every so often,until i can get it all fixed?
  2. #2 Re: Head Gasket
    Head gasket tubes? What motor so you have and what is that?
  3. #3 Re: Head Gasket
    id like to know what head gasket tube is as well?
    do you mean the plastic coolant elbows? they cost 6 bucks, and a socket wrench.
  4. #4 Re: Head Gasket
    Aug 2012
    toronto
    2000 pontiac grand prix.
    All the mech said was the tubes were worn down,and needed replacing before the gasket blows,otherwise could be 42000,instead of $260
    Thanks for the replies .
  5. #5 Re: Head Gasket
    What motor? 3.1 or 3.8? supercharged or na. Can you take a pic of what he was talking about? We have no clue what a head gasket tube is.
  6. #6 Re: Head Gasket
    Call and ask him for the actual name of the part that he thinks is bad. Cause...there's no part called HG tube on our engines.
    And the chances of a head gasket blowing on these 3800's.. well...you had a better chance at winning powerball yesterday.
  7. #7 Re: Head Gasket
    Aug 2012
    toronto
    Its a 3.8 litre engine.
    The tubes or elbows were replaced yesterday for $260.
    The mechanic had to remove a bunch of stuff to get to the gasket,labor etc..y`know.
    Thanks for the advice
  8. #8 Re: Head Gasket
    please post a pic of what he repaired if possible.
    $260 to replace what I think your calling a head tube is really a coolant elbow? Wow! Take a picture might help us more.
    04 Comp G.
  10. #10 Re: Head Gasket
    420 or 4200?
    It should be under $1000 for a LIM job.
    Maybe close to that or slightly higher if replacing the UIM as well.
  11. #11 Re: Head Gasket
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    If I had to guess I would say he has an l36 and has had issues with the intake degrading around the egr stovepipe and had the "tube" repair kit installed along with a new pair of elbows.
    Ken-Co Industries - Upper Plenum and Lower Intake Repair Kit
  12. #12 Re: Head Gasket
    Aug 2012
    toronto
    MAN YOU GUYS ARE GOOD!!
    I,ll see what i can do,but i was pretty pleased with what he did.
    The same mechanic removed the knocking sound that i heard,and that i thought was related to putting in a little too much coolant.
    He discovered it was a ball bearing in the tire,and removed it for free before replacing the elbows.
  13. #13 Re: Head Gasket
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    you get a steal on that ball bearing removal.
    These engines are easier then putting lego's together. If you get yourself a socket set, some ratchet wrenches, and this site, it could save you thousands over the life of the car.
    97 Bonneville SE Not so much a 97 anymore
  1. Head gasket and head crack questions.
    By deib in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 03:50 PM
  2. cracked head blown head gasket or just done??
    By roytoy70 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2012, 10:40 PM
  3. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  4. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  5. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
