Thread: Door locked, can not unlock or open
Results 1 to 8 of 8
  1. #1 Door locked, can not unlock or open
    SE Level Member Lowdown112's Avatar
    Dec 2012
    Louisville
    My passenger door is locked shut and wont open or unlock at all...I was outside in the rain from 4 to 10 trying to fix it... all help appreciated!!
  2. #2 Re: Door locked, can not unlock or open
    Spent my time helping you by giving your title some meaning.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Are your keys in the car and your locked out?
    Does the driver door work?
    Are you a coupe?
    Did it get into an accident?
    Are you just weak?
    Was it parked on an incline?
  4. #4 Re: Door locked, can not unlock or open
    Dec 2012
    Louisville
    Quote Originally Posted by Kolton Lock View Post
    Are you a coupe?
    Are you just weak?
    No i have my keys
    Yes my driver door works
    Im in a sedan
    No i didnt get into an accident
    No im not weak
    No im not in an incline
  5. #5 Re: Door locked, can not unlock or open
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    your fine. you can get in!
  6. #6 Re: Door locked, can not unlock or open
    Pennsylvania
    Does it unlock from the inside?
    Wonder if maybe the hinge isn't so good and the door fell low and the lock mechanism got stuck... so use some wood and a jack to lift up the edge of the door and try again.
  7. #7 Re: Door locked, can not unlock or open
    sounds like the linkage arm fell apart, for the lock.
    do you have a key fob? when you work it, can you hear the actuator working?
    Mar 2012
    Minneapolis MN
    Okay. Just verifyin some things. I have a coupe and if I park on an incline the passenger door will not open no matter what from my saggy hinge lol
    I'd check saggy hinges on the doors or the linkage arm.
