Thread: 2007 Grand Prix GXP Steering Box
Results 1 to 8 of 8
  1. #1 2007 Grand Prix GXP Steering Box
    SE Level Member WkDcLwNz's Avatar
    Orlando
    Hoping someone can provide their opinion here. I was out shopping with the wife a couple hours ago. Upon pulling in to my parking spot at my apartment, I suddenly noticed the car would not turn left. It's like there's no power steering, only when turning left.
    About 3 weeks ago, I had the car at Tires Plus for 2 new fronts, and an alignment. They told me the inner and outer tie rods were bad and needed to be relaced. I bit the bullet and had them do it.
    So tonight I took off the front driver side wheel to see if I could find anything obviously wrong. Well the boot was pulled off the rod where it goes into the steering box, as well as some sort of little vacuum line was disconencted. Bingo! Problem solved and I put it all back together. I was a bit shocked that a small tie wrap is all that was used to hold/clamp the boot down, and it had slid right off.
    But anyhow, after reconnecting the vacuum line, or whatever it is, and sliding the boot up, I started the car, but still the same problem. No left turning, and a bit of whining while trying to do so. (From the car, not the wife).
    So I have dug around online and found many, many posts suggesting the steering box is bad? Or agear in it? I know nothing about these components! So I have several questions.
    1st being if this issue was in any way, shape, or form caused by Tires Plus doing something improperly. My first thought is tobe there tomorrow morning at 7am when they open. But am I just wasting precious time in doing that? Will most likely be told that the box/gear is bad, and needs replacing? I went on every major parts site and damn near nobody even lists or carries a 2007 GXP steering box. Advance had a bunch come up, but none are "Exact fit" parts for the Grand Prix.
    So I have no idea if this part is really hard to find, how expensive, etc. This is my only vehicle and I'm already gonna miss work tomorrow trying to get this repaired. Any suggestions as to how I should proceed?
    Again, going to Tires Plus in the AM, will that just be a waste of my time? Should I just call a dealership? Any advice and suggestions would be very much appreciated.
    And just another tidbit of info. My PS fluid looks like brown sludge in the resevoir, and I smelled burning the second I removed the cap to check the fluid. Would that be an issue with the pump, or just that it was being over worked as I was driving a minute before that, and trying to turn left to no avail.
    Thank you!!
  2. #2 Re: 2007 Grand Prix GXP Steering Box
    Sep 2011
    East Jordan, Michigan, United States
    I would bring it into the dealership. Something is definately wrong.
  3. #3 Re: 2007 Grand Prix GXP Steering Box
    A guess is that the power steering rack failed.
    We dont have steering boxes.
    Given the sludge, youll want to replace everything.
    Youre not going to like this, but new racks come with new inner tie rods.
  5. #5 Re: 2007 Grand Prix GXP Steering Box
    GT Level Member GMCustomerService's Avatar
    Michigan
    Quote Originally Posted by WkDcLwNz View Post
    Thank you!!
    WkDcLwNz,
    I also recommend having the vehicle inspected by a certified technician at your local dealer.
    Please keep us posted.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  6. #6 Re: 2007 Grand Prix GXP Steering Box
    Orlando
    Quote Originally Posted by GMCustomerService View Post
    WkDcLwNz,
    Louis
    GM Customer Service
    Took her in for a check up. Turns out is was indeed the rack and pinion. Had a new one installed, but the steering was twice as hard to turn right at low speeds, than it was turning to the left. Took it back in yesterday. They said the new rack seems like it'sbinding up a bit. They are going to put another in at no charge.
    Thank you everyone for your comments and suggestions!
  7. #7 Re: 2007 Grand Prix GXP Steering Box
    Michigan
    WkDcLwNz,
    Thanks for the update. I'm happy to hear they are taking good care of you.
    If you have any questions or concerns in the future, please feel free to contact me privately.
    Louis
    GM Customer Service
  8. #8 Re: 2007 Grand Prix GXP Steering Box
    Iowa
    I had the same issue , I heard a loud thump backing out of a parking space & could hardly turn either direction. The powersteering rack broke , cost $ 700.00 to be replaced
  1. 2007 grand prix .........please help
    By fentonfamily in forum General Grand Prix Discussion
    Last Post: 05-24-2012, 09:18 PM
  2. My 2007 Grand Prix GT
    By carlover89 in forum Members Rides
    Last Post: 01-07-2012, 03:02 AM
  3. 2007 Grand Prix
    By kristinkay in forum Introductions/Noob Questions
    Last Post: 07-29-2010, 02:23 PM
