Thread: Headlamps low beam not working.
Results 1 to 2 of 2
  1. #1 Headlamps low beam not working.
    Oregon
    I have a 2006 Grand Prix. I have a head light problem that has developed with my car. It started to develop as a problem when I flicked the right turn signal on it would bump the high beams on. Then as soon as the turn signal cancelled they went back to the low beams. Just a few months ago I went to go to the store and the low beams would not come on. The next day my wife drove it and they were working again. They worked for another couple months, with no problems. Then they went out again and never came back on. I thought because of the previous problem, it was the control switch, so I replaced it. That did not fix the problem. I have read that the relays on these cars can be problem-matic. I tested the power going to the relay. Only one of the 4 slots had pwr and that did not change no matter what position the light switch was in. It would seem to me that the problem is somewhere between the switch and the relay. I also checked both fuses in the main fuse block and they are ok. I read somwhere that there are fuses in the passneger dash panel, but I did not find any that looked to be related to the head lamps. Any one have any advise?
    Thanks
    If you buy foreign don't whine about the economy.
    He who dies with the most toys, had the most fun when he lived.
    98 Grand Prix GTP / 06 Grand Prix GT
  2. #2 Re: Headlamps low beam not working.
    GT Level Member GMCustomerService's Avatar
    Michigan
    jdcowboy,
    It sounds like you may have a short, just a suggestion, not a diagnosis. Consider having the vehicle inspected by a certified technician for an official diagnosis.
    Here’s a digital copy of the owner’s manual, which may help with your question regarding the fuses: http://www.extendedgmwarranty.com/ow...-GrandPrix.pdf
    If you have additional questions, or need assistance locating a technician in your area, please feel free to contact me privately.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  1. low beam headlights not working
    By beaver in forum Introductions/Noob Questions
    Last Post: 11-01-2012, 01:05 PM
  2. My DRLs & Low Beams Are not working, high beam work
    By FlaminWhite97GTP in forum Audio, Security & Visual Electronics
    Last Post: 01-18-2010, 01:26 PM
  3. Need High Beam, Low Beam, Fog wiring help...
    By TuKoolGTP in forum General Tech Discussion
    Last Post: 12-29-2009, 12:57 PM
  4. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
