Thread: Top swap and regular gas.
Results 1 to 5 of 5
  1. #1 Top swap and regular gas.
    SE Level Member rob11715's Avatar
    Apr 2012
    New York
    Out of desperation I had to put regular gas in my car (not really a top swap but SSM90 kit - same compression). I assume if I drive like an old lady and accelerate very slowly I should be OK? My thinking is the boost bypass should be bypassing as long as I don't get on the gas pedal too hard.
  2. #2 Re: Top swap and regular gas.
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Should probably be ok. How much did you put in?
  3. #3 Re: Top swap and regular gas.
    You'll be okay, just dont beat on it.
  4. #4 Re: Top swap and regular gas.
    Apr 2012
    New York
    Thanks for the replies. I put about 3/4 of a tank in. After Sandy it's hard to get any gas. I figure I'll just accelerate super slow until I can get premium again and purge all the regular out.
  5. #5 Re: Top swap and regular gas.
    Just run it down and fill with premuim and it'll mix in and maybe be 1 point lower on the octane scale, I wouldnt worry.
  1. hp tuners... regular or pro?
    By jakewet28 in forum PCM Tuning
    Last Post: 02-20-2011, 08:02 PM
  2. How bad is regular gas for your gtp?
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 08-16-2010, 02:44 PM
  3. oil: synthetic or regular??
    By WHITEGPGT06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 06:46 AM
  4. Sythetic VS Regular 5W30
    By Fubisin in forum General Tech Discussion
    Last Post: 10-21-2009, 10:00 PM
