Thread: Car just quit
Results 1 to 3 of 3
  1. #1 Car just quit
    Oct 2012
    Brookings, SD
    I was drive and the car just died, turns over fine and I am getting gas, from what I understand the cps is probably the problem, any advice?
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Crank position sensor
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: Car just quit
    GT Level Member GMCustomerService's Avatar
    Michigan
    CPS is a possibility. I'd be happy to check my resources for any known issues if you would provide the last 8-digits of your VIN.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  1. 02 GTP, DIC and HVAC quit int.
    By bonylad in forum General Tech Discussion
    Last Post: 11-29-2012, 08:51 PM
  2. Best way to quit smoking?
    By JESSEGOTTA GP GT in forum Off Topic Discussion
    Last Post: 02-20-2010, 10:39 PM
  3. HID's quit working. any ideas?
    By mwalk00gtp in forum General Tech Discussion
    Last Post: 12-08-2008, 03:17 PM
  4. 2000 GTP Quit, Need help!
    By FoSHO99 in forum General Tech Discussion
    Last Post: 08-03-2008, 08:20 PM
