Thread: Halo headlights
Results 1 to 10 of 10
  1. #1 Halo headlights
    Oct 2012
    California
    Posted this question on the noob forum yesterday and got no response. i am no noob and i have owned two gp's and this is my second. I have done 100 percent of all of my own mods. need a little help on wiring cuase i lack the know how. i recently purchased a 2001 gtp special edition (sweeet upgrade from my 97 gt) and i want halo's. need some suggestions. heres where i need help: car already has HID's but when i use the ac or heater it only works on level 5. 1 thru 4 shut off headlights. have no idea wats wrong. maybe the current HID's are causing it?
  2. #2 Re: Halo headlights
    This thread starts with halo's, moves to A/C issues then to HIDs
    Where does one start???
    And another thing
    you say you do all the work yourself but cant wire???
    SMGPFC Member #10
  3. #3 Re: Halo headlights
    antioch ill
    prolly drawing to much power do you have a relay harness for the ballasts or it could be a bad ground
  4. #4 Re: Halo headlights
    Oct 2012
    California
    wen i say mods i mean mechanical not wiring. just want to know if the HID's are causing the problem because im already thinking of changing the headlights
  5. #5 Re: Halo headlights
    shouldnt cause that kinda problem, it wouldnt cause the blower not to work, with out other things messing up
    SMGPFC Member #10
  6. #6 Re: Halo headlights
    Oct 2012
    California
    i purchased the car with the HID's and it looks like it has the relays but i didnt install so maybe it is a bad ground
  7. #7 Re: Halo headlights
    Oct 2012
    California
    its not just the ac its also the computer that tells the boost meter and gas milage it cuts off as well
  8. #8 Re: Halo headlights
    Mar 2012
    Wheaton, Illinois, United States
    If you take the HIDs out does 1-4 work? If so, then you probably have a cheap ballast or a poor ground. I've heard of HIDs causing problems in older cars if you dont have an antiflicker/anticode capacitor installed.
    GTP Level Member apierce1289's Avatar
    United States
    And another thing
    Buy a digital multimeter and a set of bed of nails test lead adapters.
    Learn to use a dmm. Solves your problems :-P
    Sent from my DROID RAZR using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
    United States
    Could it be a weak alternator (not supplying enough current for everything)?
    But in all seriousness do a process of elimination. Try stock bulbs if you still have the stock headlights see if it works with those. Also a good ground for a relay harness is the one underneath the driver's side headlight. And learning to use a digital multimeter is a good skill. Also go over to the12volt.com they have lots of people that can help, car electronics is all they do.
  1. Halo headlights
    By its cookies in forum Introductions/Noob Questions
    Last Post: 10-20-2012, 01:03 AM
  2. Need help installing halo headlights!!!
    By deadsnake in forum Visual/Body Modifications
    Last Post: 07-09-2012, 01:51 PM
