Thread: new battery keeps dying
Results 1 to 9 of 9
  1. #1 new battery keeps dying
    Jul 2012
    Elmira, NY
    Ok to start its not my car, it belongs to a girl I like. It wont hold a charge, if it sits for like an hour or more the battery dies. Its a 1995 pontiac grand prix se, its got a new battery and alternator. I have no clue what's wrong with it, I do body work and under car care, n some small wiring jobs (speakers, amps, bypassing the ignition so it starts like a race car lol) but nothing like this, only doing it to impress her. So any help at all will mean a lot to me. Thanks in advance.
  2. #2 Re: new battery keeps dying
    Check Grounds.
    Make sure nothing is staying on when the car is shut off.
  3. #3 Re: new battery keeps dying
    you need a volt tester, test the battery with the cables un hooked, note the volts. should be 12 volts or a bit higher. then hook the cables back up, car off, see if its the same, should be real close. then start the car and test again, it should be showing at least 13 volts or more, but you dont want it to more then 14.
    if the volts drop, car off and cables back on, you have a parasitic draw somewhere killing the battery, after market radio hooked up to constant power, or something else.
  4. #4 Re: new battery keeps dying
    Sep 2011
    Copperas Cove, TEXAS
    Check Grounds.
    Unless it's her staying on....giggity
    For real though what he said.
  5. #5 Re: new battery keeps dying
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Check battery cables for corrosion as well.
  6. #6 Re: new battery keeps dying
    Jul 2012
    Elmira, NY
    Thanks, I didn't even think of checking the volts. And TexasTanker only if it was her staying on lol
  7. #7 Re: new battery keeps dying
    Voltage would only work if you had a quality DMM that was able to check to quite a few digits.
    Other methods involve measuring current while the vehicle is off. Be sure you know how to use an Ammeter. 50 mA or less is typical for older cars with basic security. Some more advanced vehicles can draw upwards of 200 mA.
    If you see a large draw, its time to play, pull the fuses and measure current. A tedious game that no one enjoys.
  8. #8 Re: new battery keeps dying
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by deuce View Post
    goto scottykilmer.com. he has a video on this very subject. the video tells how to find a battery drain.
    gpbastard
  9. #9 Re: new battery keeps dying
    Easiest way to start off is charge the battery and unhook it. Walk away for a couple hours as it appears to die quickly from your description. If you come back and the battery is dead w/o being hooked up, it's a bad battery. This does happen.
    If you still have a charge, then start the draw testing.
  1. Battery keeps dying...........PT 2
    By mallard22 in forum General Grand Prix Discussion
    Last Post: 05-11-2012, 11:30 PM
  2. Battery keeps dying...........
    Last Post: 05-08-2012, 11:37 AM
  3. 01 gt dying a lot
    By Cummins97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2011, 09:18 PM
  4. Battery keeps dying (pics included)
    By genocide in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-26-2011, 12:16 PM
  5. battery dying
    By jaketrey32 in forum General Tech Discussion
    Last Post: 07-29-2009, 05:10 PM
