Thread: fuel injector...throttle body...cataltic help!!!!!
Results 1 to 3 of 3
  1. #1 fuel injector...throttle body...cataltic help!!!!!
    Dec 2011
    detroit
    hey guys looking for some help....
    2007 gxp...bone stock. had my catalytic converter clog up on way home from indy 500. got it home and found out GM covers it till 80,000 miles. they replaced it. drove it out...turned around within a mile. running like crap and stinking bad. they changed the plugs....after 15 miles started running like hell. flashing engine light then on to steady....just like before plugs. throttle body doesnt seem very dirty. valve on throttle barley opens up with gas pedal push until its floored. is that normal? should i start with fuel filter and seafoam? its running pretty bad right now and im stuck so im looking for suggestions asap. thanks in advance if you post to this.
  2. #2 Re: fuel injector...throttle body...cataltic help!!!!!
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Ill begin by using the scanner and puling the codes....
    based off of what u said, there are numerous possibilities that could cause those issues....
    If all the sensors are ok, U have to remember that your car is Throttle-by-wire so its all electronic....check the TB motor and sensor...
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  3. #3 Re: fuel injector...throttle body...cataltic help!!!!!
    Sep 2011
    Southern Alberta, Canada
    i go with checking for codes, and while ur doing that, maybe monitor the sensors if u can.
  1. prj fuel rainl/ injector help
    By Taz Magister in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2012, 02:55 PM
  2. Fuel injector seating
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:42 AM
  3. Which fuel injector?? is there a difference?
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2010, 09:55 PM
