Thread: Taillight Moisture solution. 00 gt 2dr
Results 1 to 9 of 9
  1. #1 Taillight Moisture solution. 00 gt 2dr
    Oct 2011
    Vineland
    Other than buying aftermarket lens(oe is $125 a piece new), is there a near perfect solution to solve the moisture mystery? It's real bad on mine, to the point where my bulbs are affected.
    Any input appreciated.
  2. #2 Re: Taillight Moisture solution. 00 gt 2dr
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Bake them in the oven on low, till the glue gets melty, pull off the covers and re-seal with polyurethane, or you can go with something like Spyder Auto ALT-YD-PGP97-LED-SM Smoke LED Tail Light : Amazon.com : Automotive
    They arn't too different and are alot better quality than stock.
    Oct 2011
    Vineland
    Why bake in the oven? Isnt there a way to simply take the lens off, and slap some rtv on it?
  4. #4 Re: Taillight Moisture solution. 00 gt 2dr
    you CANNOT bake tail lights. they are plastic welded together. why do you think you have to cut the tail lights apart to clear/paint them? hm?
    drill a small hole or two in the bottom of the light to drain/vent moisture. done.
  5. #5 Re: Taillight Moisture solution. 00 gt 2dr
    Feb 2010
    Cleveland
    no baking them just makes the glue separate easier so you can just pull the lenses off. drilling a hole is a horrible idea because it doesn't fix the original problem
  6. #6 Re: Taillight Moisture solution. 00 gt 2dr
    SE Level Member jer206's Avatar
    Apr 2012
    MI
    I had an extra set of tail lights and I used a blow dryer on the outer part of the lens and it was working as I was prying it off until my the dryer blew up. I think a heat gun would work too maybe?
  7. #7 Re: Taillight Moisture solution. 00 gt 2dr
    i guarantee you cannot pull them apart without cutting them. they are not sealed with any time of glue or sealer...its plastic WELDED.
    you guys do know i've gutted tail lights before, right?
    and drilling a hole or two does fix the problem. it allows the tails to vent and even if they do get moisture in them they'll clear up on their own. you don't seal things like that, you vent them.
  8. #8 Re: Taillight Moisture solution. 00 gt 2dr
    Apr 2012
    MI
    I have never worked on them before and tried heating one like others say. It's still sitting in my garage after the dryer blew up lol. I guess I learn something new everyday lol
  9. #9 Re: Taillight Moisture solution. 00 gt 2dr
    SE Level Member 2000PrixGT's Avatar
    Oct 2012
    United States
    I did that to the head light on my Dakota and it worked great, I drilled one on each side for proper draining and ventilation.
  1. Water/Moisture on Inside of Tail light
    By Egleone6 in forum Visual/Body Modifications
    Last Post: 05-22-2018, 10:11 PM
  2. Moisture in the head/taillights
    By Ninjo in forum General Tech Discussion
    Last Post: 10-12-2013, 09:24 AM
  3. tail lamps have moisture
    By bmwdriver in forum General Tech Discussion
    Last Post: 10-19-2009, 10:52 AM
  4. Halo's Have Moisture
    By mikroehl in forum Visual/Body Modifications
    Last Post: 03-22-2009, 07:35 AM
  5. Moisture in Headlights
    By Dohner in forum Visual/Body Modifications
    Last Post: 02-19-2008, 01:39 AM
