Thread: not getting full boost
Results 1 to 3 of 3
  1. #1 not getting full boost
    Aug 2012
    so when im at wot my factory boost gauge will flicker back and forth from having full bars to one and two less what could cause that i just changed the supercharger oil would that have anything to do with it
  2. #2 Re: not getting full boost
    GrandPrix Junkie
    Mar 2012
    NC
    Sounds like the boost control solenoid (BCS.) The BCS connects to the supercharger boost bypass valve on the side of the SC. If you disconnect the vacuum hose between the solenoid and the BBV and drive it you should get full bars on the legometer at WOT.
  3. #3 Re: not getting full boost
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    did you use a real boost gauge or just the lego blocks on the dash board alot of times they dont go full boost and can have a vac/boost leak to the map sensor or if it is like my case somehow after 232,000 miles my sc wasnt putting full boost anymore would go about 2 bars off from full and sometime hit full on a cold day so i replaced it with a p&p one and it works great now hits full boost at half throttle with the new 3.35 pulley
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  1. Not building full boost
    By Wsmccoy in forum Turbo
    Last Post: 05-21-2012, 06:43 AM
  2. I have full boost now.
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 10:52 AM
  3. FWI installed!! ...still not getting full boost though...
    By 03GTPLE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 04:20 PM
  4. not getting full boost?
    By Standby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 05:43 PM
  5. HELP Not making full boost
    By 1slowhatch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 01:31 PM
