Thread: Turning the Cooling Fans on all the time
Results 1 to 10 of 10
  1. #1 Turning the Cooling Fans on all the time
    GT Level Member ls1camino's Avatar
    Laurel, MD
    I am having major problems with trans temps. I have a large external cooler and a finned pan, but the temps are still in the 200* range. Am I going to run into any problems if I rig the puller fans to come on with the ignition?
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: Turning the Cooling Fans on all the time
    You typically don't want them running when vehicle speed is faster than they are moving.
    200* really isn't overly hot. It's not ideal either.
  3. #3 Re: Turning the Cooling Fans on all the time
    Laurel, MD
    When I was on a stock trans, I never saw over 160*, even during "spirited" driving. I did the turbo swap and the stock trans was roasted in a weekend (240* all weekend). Now that my Dynotech trans is back in the car, I don't want to fry it, so I installed a finned pan in hopes of getting more cooling.
    Another thought...could my trans temp sensor be getting false readings from the downpipe being right there on top of the trans?
  4. #4 Re: Turning the Cooling Fans on all the time
    No, temp sensor is at the bottom of the trans. Well bottom of sidecover.
    Are you blanketed?
  5. #5 Re: Turning the Cooling Fans on all the time
    Laurel, MD
    Are you blanketed?
    My aftermarket trans temp sensor is installed in the plug that is at the top of the trans. I still have the problem of my stock trans turning brand new fluid into almost black fluid in a weekend.
    Yes, I have a blanket on the turbo, but the downpipe is not wrapped at all.
  6. #6 Re: Turning the Cooling Fans on all the time
    Ahhh yeah that could soak your aftermarket sensor. Does the pcm trans temp match up to the aftermarket?
    The coloration is clutch material in the fluid. I'd expect some from a fresh build, but not continual.
  7. #7 Re: Turning the Cooling Fans on all the time
    Laurel, MD
    I dont currently have the ability to live scan.
    Like I said, the fluid wasnt the only indicator of my trans going out. I went from beating the piss out of my car for the last 50k miles and never having a trans problem to swapping fluid (turbo install) and having it completely dead in less than a week.
  8. #8 Re: Turning the Cooling Fans on all the time
    Pacesetter's had that issue being so close to the bell housing, IIRC I couldn't run a temp sensor up top...I'd be willing to bet that the turbo/X-over is the source of your heat issue.
  9. #9 Re: Turning the Cooling Fans on all the time
    Laurel, MD
    As an update...I installed my giant trans cooler and the finned pan. The trans runs so much cooler now. I don't know what it was that helped more, the pan or me putting the cooler in front of the radiator.
  10. #10 Re: Turning the Cooling Fans on all the time
    Former GP Owner Chadgervais's Avatar
    Sep 2012
    Bangor, ME
    Why not? When you run the AC both fans come on, even if youre doing 80 on the freeway.
    Also.. I am completely stock. In heavy stop and go traffic my trans gets up to 206*. I saw 228 one day when it was blistering hot outside and right before my water pump was replaced. On the freeway it runs between 167 and 195 depending on weather and how long ive been driving.
    FORMER GRAND PRIX OWNER- NO LONGER ACTIVE ON GRANPRIXFORUMS.NET
    YOU MAY PM ME WITH QUESTIONS, WILL ANSWER TO THE BEST OF MY ABILITY
    FORMER RIDE: 2004 GT2, TRADED WITH 244,338 MILES. CURRENT: 2012 DODGE AVENGER
    GOD BLESS...
  1. cooling fans
    By polarisdescent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-07-2012, 04:28 PM
  2. electric cooling fans
    By kutbait in forum General Grand Prix Discussion
    Last Post: 08-10-2012, 06:28 AM
  3. cooling fans on 90 G.P.
    By TIMS TURBO in forum General Tech Discussion
    Last Post: 05-01-2012, 06:34 AM
  4. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
