Power steering pump could be going bad but check your fluid first. Change the belt. Your lower rad hose should be cooler as the top one is where the hot coolant goes into the rad. LIM gasket could be leaking. Filter and fluid with a bottle of lucas stop slip and an ext cooler will help with this.
