Thread: Issues Starting?
Results 1 to 11 of 11
  1. #1 Issues Starting?
    SE Level Member Eccentric04gt's Avatar
    May 2012
    Hazlet, NJ
    turn the key and it takes a couple tries to start up. also the time and date get reset on the clock/DIC. windows and headlights etc work still.
    i'm thinking starter or alternator. gonna have them look at it when i go into work tomorrow, what you guys think?
    Dec 2010
    DMV
    Check the cables for corrosion. Also make sure they are tight.
  3. #3 Re: Issues Starting?
    May 2012
    Hazlet, NJ
    just checked real fast for anything obvious and didn't see anything. went to see if it would still start, but now it won't at all. ughhhh -_______- it makes some funky sounds and all the lights in the car flash on/off as it tries and fails.
  4. #4 Re: Issues Starting?
    May 2012
    Hazlet, NJ
    tried to see if car will start with a jump and it did. hoping I can get to work tomorrow morning...
    Dec 2010
    DMV
    Sounds like a alternator.
  6. #6 Re: Issues Starting?
    or the battery has a dead cell
  7. #7 Re: Issues Starting?
    once your running take it to a parts store and ask them to test the battery and the alt.
    if your battery went dead either its old. check the date on it, compared to the months on it. or the alt is bad. or you left a light on.
    when they test the battery if they do it in the car it needs to read 12+ volts with the car off. running it should read 13+ to as high as 14 volts, but a 13.7 to .9 is where you want it. if when running its less then 13 volts or the same as when the car is off your alt is bad.
  8. #8 Re: Issues Starting?
    May 2012
    Hazlet, NJ
    well tonights digging is over, everything is just gonna wait till tomorrow. i work at pep boys so i'm just gonna get them to check it out. hopefully car survives the 20 min drive.
  9. #9 Re: Issues Starting?
    May 2012
    Hazlet, NJ
    turns out it was the battery.
  10. #10 Re: Issues Starting?
    woot, i guessed right
  11. #11 Re: Issues Starting?
    May 2012
    Hazlet, NJ
    seeing it in the daylight it became pretty obvious that it was a really old battery, probably the original. so it lived 97k miles lol
  1. Starting Issues
    By John Alford in forum General Tech Discussion
    Last Post: 03-08-2012, 11:36 AM
  2. Starting Issues Need Help
    By WOTFTW in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2012, 07:26 PM
  3. Starting issues!! Help please!!
    By 98 Grand Prix Gt in forum General Tech Discussion
    Last Post: 07-29-2011, 03:19 PM
  4. starting up issues / gas???
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2009, 08:42 PM
  5. Starting Issues
    By BigBird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-20-2009, 12:22 PM
