Thread: Driving with a bad power steering pump
Results 1 to 14 of 14
  1. #1 Driving with a bad power steering pump
    Mar 2012
    Bangor Maine
    Greetings,
    So im about 99% sure my power steering pump is on the way out. Considering im over 215k miles, i really cant be surprised. Im assuming the serpentine belt drives the pump?
    Either way, the other day i noticed that when i was stopped with the wheel hard over to one side, i could hear chattering coming from the area of the ps pump, sounded like bad bearings. This evening when coming off the highway at a cloverleaf, i heard the chattering again. For the past couple months, turning the wheel while stopped has been difficult, but normal when moving at least 10mph.
    Ive driven vehicles w/o ps before, i dont find it difficult. Im just wondering if i continue to drive and the pump eventually does seize, is that going to cause damage to either the belt or other components driven by the belt? I can live with a noise and without power steering, i just dont want to put anything else at risk.
    thanks
    ps. my fluid level is normal and not leaking
  2. #2 Re: Driving with a bad power steering pump
    replace your pump asap!
    driving a car with a rack and pinon, and no power to it kills it like over night. not good unless you want to spent $500 at a shop for a new rack, if you cant do it yourself.
  3. #3 Re: Driving with a bad power steering pump
    Mar 2012
    Bangor Maine
    what am i looking at parts and labor wise to have it replaced?
  4. #4 Re: Driving with a bad power steering pump
    about 70 for the part, and if you have a simple 30 piece socket set and a hours time you can do it yourself.
  5. #5 Re: Driving with a bad power steering pump
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    Depending on your replacement pump, it may or may not come with a pulley. You'll need a puller/installer to swap the p/s pulley off your junk unit to the replacement pump. Do not try and pound or press the pulley onto the shaft of the replacement pump.... the outcome will be costly.
  6. #6 Re: Driving with a bad power steering pump
    the puller, well a cheap version comes with the new pump,(its nothing more than a nut and bolt) or break down and buy a good one for 30 bucks.
    when i was looking for my new pump i saw none for sale with a pulley on it. not that they don't exist i haven't seen it yet tho.
  7. #7 Re: Driving with a bad power steering pump
    Aug 2012
    Somerset WI
    scotty, those reman units come with a cheap nut and bolt installer but nothing to get the pulley off the junk pump. Autozone and O'Riellys rent the puller/installer cheap. Pumps with pulleys already installed are out there but they are not cheap(new, not rebuilt). Seems all thats out there now are the A1 Cardones.
    Here is a tip: run a tap or thread chaser into the shaft of the reman pump. Seen alot of reman pumps with crappy threads and the installer won't thread onto the shaft
  8. #8 Re: Driving with a bad power steering pump
    this is the puller i picked up, you DO NOT NEED AIR TOOLS to do this. i used a wrench and a ratchet.
  9. #9 Re: Driving with a bad power steering pump
    Aug 2012
    Somerset WI
    The wrench and ratchet method: X2.
  10. #10 Re: Driving with a bad power steering pump
    SE Level Member Skoll's Avatar
    Jun 2012
    United States
    I can't empathize what Scotty is saying enough. I had to replace my PS pump as well, but by the time I did it was too late and now I have to get a new rack and pinion put in. The PS pump is easy to to do if you have your own car lift. If it, it's cheap to get done at a shop. A lot better than having to buy a new rack and pinon ( can cost as much as $250 ), and paying to get it in ( Another $300-$350 right there ).
  11. #11 Re: Driving with a bad power steering pump
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Quote Originally Posted by Skoll View Post
    Had the same thing happen to me too! I didnt really have a choice seeing as how I needed to use my car and was dragging my feet to take it to my mechanic friend but in the end I paid dearly for it.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  12. #12 Re: Driving with a bad power steering pump
    dont really need a lift to do the pump or the rack, i did them both in my car. the pump you need to take the pass wheel off, and you can get to the lines from there, and the rack you just put it up on jack stands and drop the back of the cradle a few inches and unbolt it all. then slide it out the d/s wheel well opening. is it fun? no, but doable. beats paying for it, thats for sure.
  13. #13 Re: Driving with a bad power steering pump
    Aug 2012
    Somerset WI
    I have to admit...I'm pretty spoiled having a hoist to do car work on. Best $3500 I have spent and it has paid for itself 10 times over.
  14. #14 Re: Driving with a bad power steering pump
    Jun 2012
    United States
    That doesn't sound fun at all, but I kind of want to try it now.
  1. 99 GT power steering pump
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-10-2011, 11:13 PM
  2. noisy power steering pump?
    By Teardrop in forum General Tech Discussion
    Last Post: 12-26-2010, 10:01 PM
  3. Need New Power Steering Pump?
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-05-2010, 01:59 PM
  4. power steering pump
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 04:26 PM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
