Thread: Key stuck in Ignition
Results 1 to 8 of 8
  1. #1 Key stuck in Ignition
    Jun 2012
    Every once in a while I will have a problem with my key getting stuck in the ignition of my 98 gtp. It comes and goes but it gets frustrating when it happens. I can turn the car off and I can turn the key down but I cant get it to go that one more click to pull it out. The ignition will get stuck in the position where the orange light will be on under the gear indicator in the gage cluster but it wont turn any further and therefore I cant pull the key out. Has anyone else had this problem and can anyone provide any help?
    Quincy, Mass
    It's a common issue, u believe replacing the ignition switch fixes it but I'm not sure.
    Anyways there's a little hole with a cover on it right under the key cylinder. Stick a pen or something, I use my key because it just comes out whenever for some reason, and until it pushes the release and you can turn the key one more click.
    No more GP 04 Impala SS Indy:
  3. #3 Re: Key stuck in Ignition
    It has nothing to do with the ignition switch, its a solenoid in the shifter that tells when the car is in park, this solenoid goes to **** and then the car doesnt think its in park so it wont allow you to remove the key. Cheepest fix remove the bottom of the steering column and zip tie the release down. There is also instructions somewhere on how to fix the solenoid problem, if you take it in to a repair shop they will make you pay for an entire shifter.
  4. #4 Re: Key stuck in Ignition
    GT Level Member Beelzeboul's Avatar
    Racine
    yeah another common reason people have to use thekey release is our cars lock the keys in ignition when the car dies..
    like he said though its a solenoid between shifter and ignition letting the car know its in park mine was figgity for a while I found tilting the steering wheel or sometimes just re entering it into park when I dont hear a click works
    ps swiggles I love your sig :P
    I'm sorry officer I didnt know I couldn't do that
  5. #5 Re: Key stuck in Ignition
    Aug 2012
    Omaha, NE
    I was not able to get this fixed without replacing the shift lever assembly, but I did it myself, it was pretty easy.
  6. #6 Re: Key stuck in Ignition
    I've had someone tell me this, and swear that the issue was the shifter and all GPs in wreckers had the shifters gone long ago.
    Solenoid seems to remove all possibility though.
  7. #7 Re: Key stuck in Ignition
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    i just ripped the solenoid out from under the steering wheel never looked back + key comes out in any gear
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  8. #8 Re: Key stuck in Ignition
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Quote Originally Posted by 1LoudGrandPrix View Post
    Me too!! Do a SEARCH, lots of older posts.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  1. Key stuck in ignition
    By tigers40 in forum General Tech Discussion
    Last Post: 07-01-2012, 05:22 PM
  2. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  3. KEy stuck in ignition
    By EJRJR91 in forum Audio, Security & Visual Electronics
    Last Post: 02-20-2011, 10:42 PM
  4. Key stuck in ignition.
    By at2smithjason in forum General Tech Discussion
    Last Post: 03-31-2010, 06:16 PM
  5. key stuck in ignition....
    By fst in forum General Tech Discussion
    Last Post: 01-21-2010, 06:06 PM
