Thread: Eating gas quicker than usual?
Results 1 to 12 of 12
  1. #1 Eating gas quicker than usual?
    SE Level Member Eccentric04gt's Avatar
    May 2012
    Hazlet, NJ
    last day at my delivery job, first day on it with my new intake. I've only been here 2.5 hours and my gas gauge has dropped a bit more than 2.5 hrs into my night shift I usually have...
    so is it eating gas because it's like 98+ outside, or did I f up my intake install?
    p.s. not a right foot issue, been driving conservatively today.
  2. #2 Re: Eating gas quicker than usual?
    Jun 2012
    Golden Eagle, IL
    what kind of intake did you put on, CAI, HAI, FWI, it will make a difference,
    if you could post a pic of it
  3. #3 Re: Eating gas quicker than usual?
    May 2012
    Hazlet, NJ
    duh lol forgot. can't upload from iPhone though, check out the thread I made 3 or 4 days ago it's got a pic in it, last post in it.
  4. #4 Re: Eating gas quicker than usual?
    Cambridge, Ontario Canada
    Your are into the pedal more because you like the whine = more gas
    2005 E55 - stock
  5. #5 Re: Eating gas quicker than usual?
    May 2012
    Hazlet, NJ
    haha if you told me that 2-3 days ago I would agree. I kept going 3k-4k revs cuz it made a nice rumble lol, but today I threw $10 in the tank and was at about half a tank. been driving 90% of the time below 2k revs, and the other 10% no higher than 3k. now I'm like a bit above 1/4 tank.
    this is my first time working the day shift, so it's the first day I've driven constantly in this heat, so I'm hoping the heat is my problem not my intake.
  6. #6 Re: Eating gas quicker than usual?
    Apr 2009
    Fort Worth TX
    A scanner may help so you can monitor AFR and fuel trims. You may have developed a vacuum leak or something.
    Calculate your exact fuel mileage.
  7. #7 Re: Eating gas quicker than usual?
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Are you running the A/C during the day and not the night?
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  8. #8 Re: Eating gas quicker than usual?
    May 2012
    Hazlet, NJ
    nah i'm to cheap to use A/C. i'm home now here's 2 pics. i'm pretty sure everything is fine it stopped dropping as rapidly a few hours after posting this, not sure what happened lol.
  9. #9 Re: Eating gas quicker than usual?
    AC is cheaper at highway speeds and windows is cheaper in town.
    I'd venture to guess fuel trims happened.
    HAI won't flow as much air (hot air is less dense), pcm will have to relearn fuel trims which it probably has.
  10. #10 Re: Eating gas quicker than usual?
    May 2012
    Hazlet, NJ
    how is AC cheaper at highway speeds? just curious. so PCM learning fuel trims should bring me back to normal?
  11. #11 Re: Eating gas quicker than usual?
    The increase in drag from leaving your windows open costs more fuel than AC does.
    Test it out.
    Yes, PCM should learn to use less fuel and you should be back to normal.
  12. #12 Re: Eating gas quicker than usual?
    May 2012
    Hazlet, NJ
    okay thats what i figured.
    thats good news. no worries for me then. i can just be happy with my install. haha
  1. Highway vibrations... (checked the usual)
    By Raviaan in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2011, 11:24 PM
  2. My fusion is quicker than my Fiance's 01 GP GT need help...
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-20-2011, 07:53 AM
  3. The usual new guy
    By sasquatch094 in forum Introductions/Noob Questions
    Last Post: 08-22-2009, 09:35 PM
  4. Not your usual question
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-29-2009, 11:29 AM
  5. Why LTFT, when STFT should be quicker
    By IndeedSS in forum PCM Tuning
    Last Post: 08-26-2008, 08:27 AM
