Thread: Routine/preventative maintenance
Results 1 to 10 of 10
  1. #1 Routine/preventative maintenance
    Aug 2012
    Missouri
    Needing to do a tune up to my car wandering what your doin to yours what do you recommend replacing and what brands are the best any input helps
  2. #2 Re: Routine/preventative maintenance
    Gai...what do joo drive?
  3. #3 Re: Routine/preventative maintenance
    Aug 2012
    Missouri
    04 grand prix gt with 92000 miles haven't had it long not sure what scheduled maintenance has been done besides oil and filter and fuel filter
  4. #4 Re: Routine/preventative maintenance
    Ok then.
    Plugs (iridium or copper stock replacement, just not bosch)
    Wires I prefer Autolite etc since they are lifetime replacement
    Clean the TB
    Clean the MAF
    That should do it. Unless your coolant needs to be maintained. Then I'd flush it and refill with anycolor.
  5. #5 Re: Routine/preventative maintenance
    Aug 2012
    Missouri
    Sounds good I was wandering what brands work best with these cars so that's what I needed to know
  6. #6 Re: Routine/preventative maintenance
    For the most part, any of the brands will work well. Bosch O2's and spark plugs seem to cause issues, so stay away from them. Otherwise..a quality and or lifetime part is always nice.
  7. #7 Re: Routine/preventative maintenance
    Topeka, KS
    Seafoam does wonders too.
    Sea Foam | How to Use Sea Foam Motor Treatment
    Watch the vid for instructions.
  8. #8 Re: Routine/preventative maintenance
    GT Level Member thegipper's Avatar
    grafton, wi
    92k too early for transmission fluid and filter change? Just a thought..
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  9. #9 Re: Routine/preventative maintenance
    Quote Originally Posted by thegipper View Post
    FSM suggests doing it every 30K
  10. #10 Re: Routine/preventative maintenance
    GTX Level Member cerick08GP's Avatar
    FWIW any car I own gets the tranny serviced every 75K, and for the first fluid change I don't go past 30k-50k. The fact is you can do a dozen fuild changes for the cost of one tranny replacement.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  1. Doing some maintenance
    By GoldGTP in forum General Tech Discussion
    Last Post: 03-17-2011, 01:39 PM
  2. car maintenance
    By cerick08GP in forum Off Topic Discussion
    Last Post: 11-29-2010, 02:33 AM
  3. maintenance fun
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 12:21 AM
  4. Driving 99 GT across country 150k mi - Preventative maint?
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-06-2010, 01:05 PM
  5. Car maintenance
    By ReaperRob in forum General Tech Discussion
    Last Post: 02-05-2010, 02:01 AM
