Thread: Don't know where my coolant leak is coming from?
Results 1 to 6 of 6
  1. #1 Don't know where my coolant leak is coming from?
    SE Level Member sseigtp's Avatar
    Milwaukee, Wisconsin
    I have a light trail of coolant on top of the tranny on the driver side of the car. My guess is the lower intake manifold. but the car has a new aluminum lim gasket and new sc gasket and they were leak free for 6 or 7k miles. it was leaking in the same spot before i put the aluminum lim gasket on. im debating on whether or not it could possibly be the head gasket. there is no coolant in the engine oil, i check it frequently. what do you guys think?
    Also next week im putting on new 1.9 rockers and 90# springs. i just wanna make sure i don't have to do anything twice
  2. #2 Re: Don't know where my coolant leak is coming from?
    Tb gasket?
  3. #3 Re: Don't know where my coolant leak is coming from?
    I will look at that tomorrow when its light outside, i didn't think to check there! Those are also all new when i did the gen v swap, kept the L67 tb.
  4. #4 Re: Don't know where my coolant leak is coming from?
    Either a tb gasket or the turn around gasket. There is a little cover right below the TB.. it can/will leak.
  5. #5 Re: Don't know where my coolant leak is coming from?
    Alright just took a look and its green under the tb adaptor, so now I'm gonna use high temp rtv. Thank you fivefingerdeathpunch. I didn't think to look there. I was scared it was a bigger problem lol.
    Quincy, Mass
    If tap and plug the little coolant holes on the lim you wouldnt have that problem, and you'd be able to remove the tb and sc without draining the coolant
    No more GP 04 Impala SS Indy:
  1. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  2. cant figure out where this leak is coming from.
    By Drews in forum General Tech Discussion
    Last Post: 03-22-2012, 04:48 PM
  3. I have an antifreeze leak coming from the intake
    By lzicc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2010, 01:36 PM
  4. Low coolant light keeps coming on
    By rjo98 in forum The Rant Forum
    Last Post: 10-14-2009, 08:08 PM
  5. coolant low light keeps coming on
    By Lance in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 10:28 PM
