Thread: Steam coming out when removing dipstick?
Results 1 to 7 of 7
  1. #1 Steam coming out when removing dipstick?
    GT Level Member RideWithPride's Avatar
    Oct 2011
    383 miles rebuilt engine, pulled over because my car seemed to be shaking a little more than ussual and i popped the hood lifted the dipstick and it was kind of smokey steamy is this bad?
  2. #2 Re: Steam coming out when removing dipstick?
    Pennsylvania
    I know I usually have some vapor coming out if I open up the oil cap after running the car, is your oil level increasing/coolant level decreasing? Any milkshake looking substance?
    Might be just blowby from the cylinders
    Sport Edition Kv5 18x8
  3. #3 Re: Steam coming out when removing dipstick?
    Pennsylvania
    Also, check out all of your vacuum lines and electrical connections and stuff, if there's only 400 miles on it stuff could've popped loose
  4. #4 Re: Steam coming out when removing dipstick?
    Oct 2011
    Quote Originally Posted by FriboRage View Post
    Ive been wanting to do this but i dont know how, how do i check for leaks do i need a machine?
  5. #5 Re: Steam coming out when removing dipstick?
    St. Louis
    Nope, just spray some carb cleaner around all the vac. fittings while it's running. If you find a spot that makes the RPM's increase/decrease then that's a vacuum leak.
  6. #6 Re: Steam coming out when removing dipstick?
    Aug 2012
    osage
    stuck pcv valve could also be the problem
  7. #7 Re: Steam coming out when removing dipstick?
    If you have the car running and pull the valve cover cap..is there a vacuum or pressure that you notice? That's the quick easy test for a pcv issue.
    Could be breaking in and might be normal. Check all your fluids though and note if the coolant is low.
  1. Now that's using your dipstick......
    By alkygto in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 06:38 AM
  2. Rebuilding an Engine, Steam Cleaning Internal
    Last Post: 02-07-2011, 10:27 PM
  3. releasing some steam
    By cojo in forum The Rant Forum
    Last Post: 04-13-2009, 08:49 PM
