Thread: Replaced Hub Bearings and CV axles. Now I have a host of issues
Results 1 to 4 of 4
  1. #1 Replaced Hub Bearings and CV axles. Now I have a host of issues
    Aug 2012
    New York
    ABS and Brake light are staying on, but more over, When I replaced the left side axle, it was not going in over the ring pin. I took off the ring and placed inside the new axle (in the groove of course). It was still not going on as easy as it should so I used a hammer and "gently " tapped it in. I believe it seated, but now it appears to be leaking. Not sure if I damaged the seal on removal, or did some more serious damage forcing it in place. Can any damage occur that way?
  2. #2 Re: Replaced Hub Bearings and CV axles. Now I have a host of issues
    Omaha, NE
    Did you make sure you plugged all the abs wire clips back in?
    Do a good visual and physical inspection of the boot. It doesn't take a whole lot to rip them.
  3. #3 Re: Replaced Hub Bearings and CV axles. Now I have a host of issues
    Aug 2012
    New York
    Yes. The both sides are clipped it. The leak looks like the transmission seal (tranny fluid) seal, but I am hoping I did not screw it up by using the hammer. If so I guess I am replacing the shaft as well. Hard job ??
  4. #4 Re: Replaced Hub Bearings and CV axles. Now I have a host of issues
    Buy a new seal and pull the axles again and install it and throw it back together.
  1. Axles???
    By GRAND98 in forum General Tech Discussion
    Last Post: 07-13-2012, 09:10 PM
  2. What CV Axles to use
    By indygrandprix in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2012, 04:49 PM
  3. Spun bearings after mechanic replaced head gaskets, UIM and LIM
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-13-2011, 03:41 PM
  4. Best cv axles
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 09-24-2010, 08:11 AM
  5. Host from Millionaire on the prowle
    By BoostedComp in forum Off Topic Discussion
    Last Post: 10-18-2009, 11:05 PM
