Thread: Transmission service.
Results 1 to 9 of 9
  1. #1 Transmission service.
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    So, it's been a while since I've dropped the pan on a transmission, I'm taking care of my grand prix on Saturday.
    I can't remember is it best to do it with the fluid warm or cold? When the pan is off if I pour a quart into the fill tube will it push old fluid out of the converter or just run straight through? Also the filter needs to be "primed" correct?
    Sent from my ADR6425LVW using Tapatalk
  2. #2 Re: Transmission service.
    Aug 2011
    Bucks County Pa
    Do it warm, you don't want to get burned.
    Just do the pan drop with new filter and trans fluid.
    2 gallons of Dexron III is all the fluid needed.
    Reuse your old original gasket, clean it up before reinstalling.
    Make sure you clean the pan and magnet good.
    It shouldnt take longer than a hour.
    I just did it last month.
  3. #3 Re: Transmission service.
    ^^^ that.
    Filter can't be primed per say, because once its back in there, there is 8 quarts of fluid to be dumped inside the trans which auto fills its anyway.
  4. #4 Re: Transmission service.
    GTX Level Member AKGTP19's Avatar
    Mar 2013
    Fort Lauderdale, FL
    I don't know the last time my pan was dropped by the previous owner but wth my gtp, I can literally feel the car move with every shift and 3rd and 4th gear are real hard shifts and sometimes when it goes into 4th, after it shifts it like goes rum rum rum and doesn't sound right so I'm probably gonna drop my pan, check the trans mounts and hope I don't need anything done to the transmission
    1998 GTP Loudmouth
    1999 GTP, Borla Cat Back.....SOLD
  5. #5 Re: Transmission service.
    SE Level Member MGRead's Avatar
    Jun 2012
    Coral Spring, Fl
    Where is the best place to order the tran filter?
  6. #6 Re: Transmission service.
    napa
    04 Comp G.
  7. #7 Re: Transmission service.
    Jun 2012
    Coral Spring, Fl
    How do I know what parts I need. do I just give napa my vin number
  8. #8 Re: Transmission service.
    Just tell them the year and wht motor and they should be able to pull it up
    04 Comp G.
  9. #9 Re: Transmission service.
    Jun 2012
    Coral Spring, Fl
    ok
  1. Replies: 5
    Last Post: 02-01-2017, 09:35 PM
  2. Transmission Service, Need Advice
    By bjornbjorn in forum General Grand Prix Discussion
    Last Post: 10-15-2013, 07:05 AM
  3. Comments Wanted - 05 Comp G Service Stability/Service Traction
    By JD05CompGTP in forum General Tech Discussion
    Last Post: 03-13-2012, 08:21 PM
  4. should i service high milege transmission
    By djwright1980 in forum General Tech Discussion
    Last Post: 03-18-2011, 05:57 PM
  5. Transmission Service
    By cowmilker08 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2010, 11:08 PM
