Thread: RPMs stay at 1500?
Results 1 to 9 of 9
  1. #1 RPMs stay at 1500?
    Jul 2012
    United States
    Hey everyone,
    I need some help trying to figure out whats up with my Grand Prix. Its an 01 3.1 liter engine. But basically whenever I start using A/C or heat the RPMs stay stuck at 1500. Then there are other times when I start the car up and it will shoot up to 2000 RPMs. Have any of you had these issues before? What's wrong and how can I fix it if you have?
    Thanks!
  2. #2 Re: RPMs stay at 1500?
    you probally have some bad vac leaks, being a 3100, i hear they have vac leaks all the time.
  3. #3 Re: RPMs stay at 1500?
    ^^that.
  4. #4 Re: RPMs stay at 1500?
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Question is vague, are you saying when using HVAC that the accelerator has no control?
  5. #5 Re: RPMs stay at 1500?
    vac leaks cause un metered air, and yes will raise your rpms. also the a/c vents are vac operated, so your demading vac pressure the car dont have to offer any more.
    check all you vac lines for cracks or dead rubber connectors.
    you can also while the car is running spray carb cleaner around the engine, and listen for the rpms to jump up or down. if it fluctuates, your leak in in the are you last sprayed.
  6. #6 Re: RPMs stay at 1500?
    I'd clean the TB if it hasn't been done. Check throttle cables.
  7. #7 Re: RPMs stay at 1500?
    Jul 2012
    United States
    Quote Originally Posted by mechguy View Post
    The accelerator slowly creeps up when using HVAC
  8. #8 Re: RPMs stay at 1500?
    The pcm is programmed to raise the idle slightly with the AC compressor engaged. Via the IAC
  9. #9 Re: RPMs stay at 1500?
    Apr 2012
    Cleveland, Ohio
    My vacuum leak was the egr tube it had a hairline crack where it connects at the intake. Trip to Ed's- Fixed.....
  1. New guy, My GTP (my $1500 Special)
    By Peacher213 in forum Members Rides
    Last Post: 02-24-2012, 11:06 PM
  2. Stumble at 1500 RPM
    By fuzzbutt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-02-2011, 04:34 PM
  3. car surges at 1500 rpm at 55 mph
    By Mean Green 99 GTP in forum General Tech Discussion
    Last Post: 03-06-2010, 11:01 AM
  4. 1500 rpm cut out or misfire
    By Planeboy18 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2009, 01:38 PM
