Thread: Ported Throttle Body 04-08 GP
Results 1 to 5 of 5
  1. #1 Ported Throttle Body 04-08 GP
    SE Level Member Nathan07GP's Avatar
    Mar 2012
    San antonio
    I have a 2007 base pontiac grand prix i had an extra throttle body lying around from a previous grand prix and decided to take it to get ported. I had it ported and it made a huge difference. It ran for about 2 minutes and than started saying reduce engine power. I disconnected the battery and tried it again. Same Results so i had to put my old throttle body back on. Does any one know if i need a tune to support all that extra air flow??
  2. #2 Re: Ported Throttle Body 04-08 GP
    If you cant outflow your stock TB, then you dont need it.
    And yes, you'd need a tune if you port the throttle body.
  3. #3 Re: Ported Throttle Body 04-08 GP
    Mar 2012
    San antonio
    That would explain. Thanks man
  4. #4 Re: Ported Throttle Body 04-08 GP
    You also have an N/A 3800.
    The L26 is plenty of airflow, you won't need to upgrade...that and it is a DBW TB...so it isn't as easy to upgrade as the cable driven '03 or older cars are.
    Also, if that is a breather filter on your oil cap...put the stock cap back on...that is only causing a vacuum leak letting in post MAF un-metered air get by.
  5. #5 Re: Ported Throttle Body 04-08 GP
    Mar 2012
    San antonio
    alright thanks for the advice
  1. Ported throttle body
    By Vlad0691 in forum General Tech Discussion
    Last Post: 01-13-2011, 03:23 PM
