Thread: High Idle 2003 grand prix 3.1
Results 1 to 3 of 3
  1. #1 High Idle 2003 grand prix 3.1
    Jun 2012
    Tampa Bay
    The car has been idling high for a few days . These codes came up , 10128 ,P0135, PO401 ,P1635 ..I am not sure if any of these has to do with idle control .
    It wants to idle around 1500 rpm and higher . I disconnected the TPS and it dropped the idle to around 900.
    I took off the TPS and it had a broken spring ,I replaced it .
    It still idles high , when I disconnect it , it will idle normal .When plugged back in while running it will also idle at around 900 .
    If I shut it off and restart it will again idle high around 1500 too 2000 rpm .
    The throttle body has also been cleaned .
    Is there something I am missing or doing wrong ?
    Is there a way to reset the computer to recognize the new part or a way to adjust the idle back to normal ?
    thanks in advance , James
  2. #2 Re: High Idle 2003 grand prix 3.1
    Jun 2012
    Tampa Bay
    I Unplugged the TPS ,drove it a few miles with no problem . Got Back , shutdown and restarted and plugged it back up ,it again idled high .
    I unplugged it ,plugged it back in while running and it idled back down to normal .
    When I shut it off cranked it back up again , the Rpms was again high around 2000.
    The TPS is new and seems to work only when it wants to .
    What am i missing here ?
    Any clues or suggestions ?
  3. #3 Re: High Idle 2003 grand prix 3.1
    Apr 2015
    Albany NY
    Have you looked at the IAC? (Idle air control valve)
  1. My 2003 Grand Prix GT New Pics
    By GrandprixGT01 in forum Members Rides
    Last Post: 06-19-2013, 09:33 PM
  2. 2003 Grand Prix GT - Engine Idle Racing
    By funkro in forum General Tech Discussion
    Last Post: 08-08-2011, 11:12 PM
  3. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
