Thread: weak 97 pontiac grand prix GThttp://www.grandprixforums.net/images/smilies/th_scratch
Results 1 to 7 of 7
  1. #1 weak 97 pontiac grand prix GThttp://www.grandprixforums.net/images/smilies/th_scratch
    SE Level Member Joe Perez's Avatar
    Jul 2012
    Douglas AZ
    Hello
    I been working on my 1997 Grand Prix gt for over a year and it just wont finish to get it fixed... the major problem is, that my car looses power after running it for a little while, especially driven on city. when I start the car on the mornings, it will run great with full power, but after a little while of heat on running engine , feels pretty heavy and burns fuel faster. This happened after I overheated my car one day maybe a year ago, and blew of a head. I replaced a head with a rebuilt one and set the new gasket kits for top engine. And also replaced water pump, spark plugs and wire set. After every thing was done and back to place, the car had a weird knocking sound on the engine, the mechanic said, that it was only a lifter, and that it could be fixed with an additive (Lucas)... It never did. After that day I took it for a test drive, and my car was running very slow and smelled really bad like gas. I took it back to the mechanic and have him replaced the fuel injectors...The car was running better after that, but i notice that every time the car ran for a little while randomly looses power, so I did a good tune up replaced a bunch of sensors like the map sensor, maf sensor, idle sensor, purge valve sensor solenoid, canister vapor tank, transmission fluid and filter, cleaned the throttle body, I even put high performance cables and a intake kit. I even replace the fuel filter and checked the fuel pump. two days ago I replaced my whole lifter valve kit and that knocking sound still there, the mechanic said it could be the camshaft. the car its been running better, but still not like it use to. some one told me that it could be the o2 sensors, but my check engine light isn't on, and I was thinking it could still be that, because when the overheat problem happened a lot of water came out of the pipes. please some one help me, I pretty much tried every thing so far, and I really like my car I would hate to get rid of it.
    Thanks!
  2. #2 Re: weak 97 pontiac grand prix GThttp://www.grandprixforums.net/images/smilies/th_scr
    Mar 2012
    NC
    May have hurt the piston rings. It happens on cars that get overheated. Do a cold and hot compression test and that will give you a good indication.
  3. #3 Re: weak 97 pontiac grand prix GThttp://www.grandprixforums.net/images/smilies/th_scr
    Jul 2012
    Douglas AZ
    hey thank you! I will try that
  4. #4 Re: weak 97 pontiac grand prix GThttp://www.grandprixforums.net/images/smilies/th_scr
    Mar 2012
    NC
    no problem
  5. #5 Re: weak 97 pontiac grand prix GThttp://www.grandprixforums.net/images/smilies/th_scr
    St. Louis
    I wonder if when you were getting all that fuel in there if it didn't clog up the cat. Do you have a had time getting it to run above 3K rpms when it's hot?
    Also, can you define what "intake kit" you installed? If it's a K&N setup then your new MAF is likely coated in oil and needs to be cleaned with the approved cleaner or electronics cleaner.
  6. #6 Re: weak 97 pontiac grand prix GThttp://www.grandprixforums.net/images/smilies/th_scr
    The reason you lose power once the vehicle warms up is KR. Your knock sensors aren't active until 160F. Once the car reaches that and the knock sensors pick up the noise...the pcm pulls timing. Sorry to say..whatever that knock sound is...that's the issue.
  7. #7 Re: weak 97 pontiac grand prix GThttp://www.grandprixforums.net/images/smilies/th_scr
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    so bill your saying that if i have my car up to temp (195*) and hammer on it and get 5* of KR that wont occur if i just start the car up (0*) and hammer on it right on start up ill get no KR but the knock will still occur so to say and thats harmful to my motor?
    ps i know i didnt use the most technical terms
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  1. New member and first time Pontiac Grand Prix owner (first pontiac ever)
    By Lexiconix in forum Introductions/Noob Questions
    Last Post: 11-10-2010, 09:45 PM
