Thread: Fuel Pump Relay Problems
Results 1 to 3 of 3
  1. #1 Fuel Pump Relay Problems
    Jun 2012
    My 98 GTP is burning fuel pump relays and I dont know what is causing it. It went threw 2 in 2 weeks about 2 months ago, then the problem went away and now just yesturday it started to burn the fuel pump relay thats been in there for the last 2 months so I replaced it with a new one and the new one burned out within 45 minutes. Does anyone know what might be causing this and is there anything I can do?
  2. #2 Re: Fuel Pump Relay Problems
    What size fuse is on that circuit? Maybe there's a corroded contact in the fuse box behind it..but a relay is a magnet that closes a circuit and relays higher power to the fuel pump.
  3. #3 Re: Fuel Pump Relay Problems
    Jun 2012
    I believe it is a 15A fuse.
  1. No power to fuel pump relay from PCM? *Update issue resolved*
    By txslow6 in forum General Tech Discussion
    Last Post: 08-10-2011, 09:23 AM
  2. 2000 GTP fuel pump relay problems
    By torqueaddict in forum General Tech Discussion
    Last Post: 06-11-2011, 07:14 PM
  3. Fuel pump problems
    By Joe in forum General Tech Discussion
    Last Post: 01-15-2011, 12:04 PM
  4. Fuel pump problems?
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 07-10-2010, 11:43 AM
  5. p0230 fuel pump relay circuit
    By Golgo13 in forum General Tech Discussion
    Last Post: 02-27-2009, 10:31 AM
