Thread: WOT question?
Results 1 to 7 of 7
  1. #1 WOT question?
    Springfield Missouri
    So I was just curious that what is the best way to go about getting the best power when hitting the throttle in my gp. Would it make more power if I eased into the throttle more and more or if i just hammer it? If anyone does track racing when the light hits green do you floor it or progressively push down on the throttle?
  2. #2 Re: WOT question?
    the whole idea is to put as much power down to the ground with out spinning the wheels, so you need to adjust as needed for take off, if it dont spin, floor it.
  3. #3 Re: WOT question?
    Kemmerer, Wyoming
    my tires always spin when I floor it. im thinking about switching to a wider wheel and tire. what most people do is put there car in 2nd gear and put the park brake on then start spinning the tires and release the brake
  4. #4 Re: WOT question?
    Apr 2011
    Vassar, Mi
    Quote Originally Posted by johntremell View Post
    wait wait...What? I knew ive been doing it wrong all along! New PB 60ft here I come!
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  5. #5 Re: WOT question?
    new britain, ct
    lets clarify this. people dont START in second gear. people put the shifter in 2, because racekar, and they are starting in first.
    07 Black GXP.
  6. #6 Re: WOT question?
    May 2008
    Winnipeg, MB
    turn traction control OFF
    then give it just enough gas to NOT spin the tires
    once your moving just floor the rest of the way to the finish line
    2007 Pontiac Grand Prix
    Ohio
    Brake boost it off the line up around 2k. When it rolls off the line then put it to the floor
  1. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  2. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  3. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  4. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
