Thread: Cooling Fans Operating correctly?
Results 1 to 3 of 3
  1. #1 Cooling Fans Operating correctly?
    Donating Users vegasridercc's Avatar
    Carson City, Nevada
    drove my 97 GT to work with outside temp around 80 degrees when I noticed the temp gauge floating around 250 or so, my thoughts were that I just changed the stat, new hoses, new radiator, etc.. when I parked the A-F just poured out the reservoir vent (small hole on side), well later that evening when I got off work, I got in and drove it home with no problems (cooler temp around 70 ish). I know my cooling fans work, but they dont spin as fast as I would like and I think this may be the problem with the heating situation.
    A/C not in operation either!
    Has anyone experienced this? and if so, was it the fans and is there a way to increase the fan speed? or just get another set?
  2. #2 Re: Cooling Fans Operating correctly?
    Did you bleed the system of air?
  3. #3 Re: Cooling Fans Operating correctly?
    Carson City, Nevada
    will try this in the morning, but not sure why it would act up now.. as I never had this problem before..
  1. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  2. cooling fans on 90 G.P.
    By TIMS TURBO in forum General Tech Discussion
    Last Post: 05-01-2012, 06:34 AM
  3. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  4. cooling fans not operating properly
    By 98grannyprix in forum General Tech Discussion
    Last Post: 07-06-2011, 02:53 PM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
