when setup correct its fine.
it all depends on the tune and pulley size with the amount of boost your putting down.
a good streetable cam is the VS cam, as well as the XP and s1x.
the s1x and XP are pretty similar in terms of powerband, they both make power in the mid to higher rpm range, but the VS cam likes to make power in the lower to midrange rpm's. if you get a cam though, make sure to get different springs. i suggest crowe 105's.
also you NEED to have a way to tune if you do any pulley dropping.
Doing the work yourself? Rockers headers 3.4 and port a bit should get you there, I ran a 12.7 with just that some slicks and 200lbs of weight reduction. If i have $800 in mods I'd be suprised.
seats, spare tire and trunk carpet etc etc, that kind of stuff.
Alum subframe, GA brakes, aztek front bumper support, alot of aluminum brackets for stuff
I know a guy in 12's with nitrous and only 2k spent on it. Port your SC and LIM yourself (Heads too if youre comfortable and can get a cheap valve job), open cone, headers, rockers/cam/nitrous, pulley, tune. there ya go.
i know about a guy that got a regal into the 11's on less than $1,000
Yeah the guy who made the 2600lb regal, that thing was pretty nuts too bad it lost pretty much all functionality in the interior.
What could you possibly remove from a 98 gtp other than the spare tire and a jack to reduce weight?
Tons of crap...
rear seats, passenger seat, center console, floormats/carpet, diagonal braces, cruise control, AC, headliner, door sills, window wipers & motor...etc.
Otherwise to answer this question: Cheapest way to a low 13's GTP?
Race gas, 3.4" pulley, dropped exhaust, open cone intake, slicks, weight reduction, and a prayer it doesn't explode the second you hit the gas.
That should do it.
take all seats out, replace only drivers seat with lightweight sparco or other seat, take out the interior trimming, speakers, run low fuel, ummm...im blanking but theres more probably.
I seriously have taken none of that stuff out.
I removed the ABS 5lbs, and no more random abs'ing to a halt when I hit a pothole
the metal bracing under the kick panel 4lbs
the engine lift brackets 4lbs
replaced the dog bones with aluminum turnbuckles was about 3lbs
headers actually are about 15 lbs lighter than manifolds, and no cat is lighter as well.
The sound proofing in the front fenders that just soaks up water was gone as well as the foam and metal in the doors from when i replaced the window motors there is also some foam in the body in the rear-seats that can go. yup 12 lbs from all of that crap and the car is not any louder on the inside with new door gaskets.
Ever go to a concert and turn your back to the stage? nope didn't think so so why not get rid of the back speakers and just get good 5.25" up front that saved about 10lbs
The rear middle seatbelt that no one has ever used because these cars aren't meant for 3 adults in the back? yup 3 more lbs there. when the battery died I replaced it with a 75 series, that saved about 10lbs
Grand am brakes are the same size and all aluminum saved 21 lbs.
Aluminum subframe that will also never rust 26lbs.
Aztek front bumper support also aluminum and will not rust was 9lbs.
Behind the rear seat is a very heavy rubber and foam mat that is about 8 lbs that can easily be taken out with no repercussions.
the big cardboard piece that never fits right on top of my spare tire? gone 5lbs and just throw the big heavy mat over it.
Wait actually that can go too just leaving the light carpet one behind over the spare that's another 4 lbs.
My company makes aluminum bolts and screws so when I have a non-shearing application I've replaced them. another 3-4 lbs over a car.
Also that plastic gas tank to run e-85 eventually is a solid 8lbs lighter
Just effiecient things and if you looked or rode in my car the only thing you would ever notice different would be the speakers probably.
Can you not add? He seriously just put all the weights in that quoted comment guy.
Calculator use one. Roughly 150lbs he saved.
^ he meant how much $.
low 13's gtp, Open headers, ported blower, intake and a 3.4 with driver mod.
I picked mine up from a junkyard for $50, while I was swapping a rack and pinion and motor mounts, so I decided why not.
The GA brakes were a matter of getting new calipers and some R1 concept rotors, but I was going to replace those anyways, in total it ran about $300 with EBC Yellow pads.
For being comfy, that's why I kept the A/C, Heater Core, blower motor, heated seats, stereo and wipers defrost etc. Not going to lie it's a little bit noisier on the inside but probably the equivalent to driving a S-10 or Ranger around which doesn't bother me or my dog at all since most of the time the windows are down anyways.
Im so glad you asked. Will this list work for you?
Dead Weight(lbs):
___________________________________
lexan/plexi windows 116
***rear window 40
***sunroof 24
***rear glass 17
***rear motors 10
***front glass 14
***front motors 10
catback exhaust 65
bumper supports 60
***rear bumper support 29
***front bumper support 23
***rear styrofoam insert 4.5
***front styrofoam insert 3.5
passenger seat(04+) 52
passenger seat(97-03) 42
spare tire and jack 35
AC system 32
***compressor 9
***duct 8
***condensor 6
***fan motors 6
***other parts 2
***controls 1
door panels(04+) 29
***front door panels 15
***rear door panels 14
race seat 29
weather stripping(04+) 26.5
aluminum cradle 26
rear seat 26
***upper part 17
***lower cushion 9
carbon fiber hood 25
door panels(97-03) 25
***front door panels 13
***rear door panels 12
race battery 26.5
***battery weight savings 25
***battery tray 1.5
heater box 25
carpeting 24
***front 8.5
***rear 8.5
***trunk 7
insulation 23.5
***front 12
***inner firewall 4.5
***rear 4
***trunk 3
wiper system 18.5
***wiper motor/bracket 8
***washer fluid 8
***washer fluid tank/pump 1.5
***wipers 1
sway bars 18
***front 9
***rear 7
***front endlinks/brackets 1
***rear endlinks/brackets 1
headliner 15
airbags 13
***passenger airbag 9
***driver airbag 4
underhood shields/brackets/ect. 12.5
***engine lift brackets/heat shields 5
***cross braces 3
***engine cover 2
***hood braces 1.5
***alternator brace 1
***hood cover 1
dash paneling/covers 12
***glove box 5
***upper dash panel 2
***center panel 1.5
***gauge cover panel 1.5
***lower passenger dash paneling 1
***fusebox covers 1
side skirts 11
seat belts 10.5
***rear 8
***front passenger 2.5
Bonneville coilpack bracket 10
ABS 10
center console 8.5
***console panels/wires 7
***center console cover 1.5
Evap system 5.5
***larger evap canister 3
***hoses/alum tubing/other 2
***smaller evap canister .5
headunit 5
rear mud flaps 5
lower front bumper panel 5
headlight(04+) 4.5
upper motor mount 4.5
floor mats 4
***front 2.5
***rear 1.5
HUD box 4
front mud flaps 3.5
EGR system 3.5
cruise control box 3
fog lights(04V6+) 3
Onstar box 2
air tubes 1.5
rear spoiler 1.5
horn 1.5
front fascia 1
rear view mirror 1
rear fascia 1
rearspkrs/amp 1
rear paneling/speaker cover 1
trunk cover .5
Rotating Mass:
skinnies 42
Grand Am brakes 20
front 15" rims/slicks 10
front 16" rims/slicks 8
lighter torque converter 6
lighter balance shaft 5
Why would you need new pistons if going with nitrous? You wouldn't happen to be a former Foxbody owner would you?
nice list.
