Thread: Rear Speaker Issue
Results 1 to 6 of 6
  1. #1 Rear Speaker Issue
    Jun 2012
    United States
    My rear speakers are temperamental. Just got car about 2 months ago. Rear speakers work fine when it's hot outside and daylight. Usually at night as well in cooler temps they stop working. Any suggestions please?
  2. #2 Re: Rear Speaker Issue
    Omaha, NE
    Have you checked the wiring?
  3. #3 Re: Rear Speaker Issue
    Jun 2012
    United States
    At the risk of sounding totally ignorant, I don't know where to begin
  4. #4 Re: Rear Speaker Issue
    Omaha, NE
    The clips on the speakers would be a good start.
    Know how to use a mulitmeter?
  5. #5 Re: Rear Speaker Issue
    Jun 2012
    United States
    I have checked the clips. Sorry, but not sure what a multimeter is. Maybe you could tell me, I may know and don't realize what it's called It's so crazy. It isn't like they cut in and out or that they have a static sound. They just work when it's nice and hot and when temp cools off (like at night) they quit and only the front works. Was out last night, headed home around 11:30...working fine, just a bit cool outside, but after I traveled 2 or 3 miles they stopped working. It was like the car was still warm, but when I got to driving and the wind cooled it off, they stopped.
  6. #6 Re: Rear Speaker Issue
    Omaha, NE
    A multimeter is a tool that measures voltage to a wire. You usually put a red prong on what you want to check, ground the black prong and look at the screen for your info.
    Heres a "classic" looking one Amazon.com: Palm-Size Handheld Digital Multimeter, DT830B: Home Improvement
    From the fact that temps change wether they work or not, and you have checked the connection on the speakers, I would assume that you have a wire shorting out or a bad ground. Checking the voltage with a multimeter should tell you if it is the wiring. If that isn't the case, it is most likely something internal on the speaker itself.
    Also, I should have asked previously, but is the audio system completely stock?
  1. Speaker issue
    By RegorHtims in forum Audio, Security & Visual Electronics
    Last Post: 12-29-2011, 11:00 PM
  2. Help on rear speaker wiring
    By 06PONTGP in forum Audio, Security & Visual Electronics
    Last Post: 06-03-2011, 09:56 AM
  3. Rear Speaker Amp
    By zildjian102 in forum Audio, Security & Visual Electronics
    Last Post: 12-06-2010, 01:01 PM
  4. rear speaker covers
    By a98gtp4u in forum Audio, Security & Visual Electronics
    Last Post: 11-15-2009, 08:50 PM
