Thread: horrible noise
Results 21 to 40 of 50
  1. #21 Re: horrible noise
    GT Level Member JesseBranham's Avatar
    Apr 2012
    Myrtle Beach, SC
    I'm pretty sure that thats not it. It sounds like popping. I will try to get a video up tomorrow.
  2. #22 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
    OK sorry for no video but I will definitely have one tomorrow. It sounds like creaking and popping and only when Im going slow.
  3. #23 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
  4. #24 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
  5. #25 Re: horrible noise
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I'd take them apart and put them back together. Make sure everythings on right. Maybe the clip that holds the pads in is broken
  6. #26 Re: horrible noise
    Did you grease up the slides and where the pads sit when you did the brakes?
  7. #27 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
    Yes.
  8. #28 Re: horrible noise
    so this noise is after you did the brakes, or just started to happen?
    i'd take it apart and recheck everything, could be a cracked pad or something. either way.
  9. #29 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
    It happened about 1 month after I did the brakes.
  10. #30 Re: horrible noise
    yeah open them up, see whats going on in there, thats not healthy sounding at all.
    if your getting a pull to one side or another when you hit the brakes and let the wheel go, but it goes straight when you are not on the brakes, you would defiantly have a problem.
  11. #31 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
    Any ideas?
  12. #32 Re: horrible noise
    Did you pull them back apart and recheck everything and grease the slides and where the pads sit?
  13. #33 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
    Yes.
  14. #34 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
    I've replaced both hubs and I'm thinking it might be the rotors. Any ideas?
  15. #35 Re: horrible noise
    It's possible. What all have you changed thus far? I'm to lazy to go back and read it all.
  16. #36 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
    Just the two front hubs. And my ABS light is on if that helps.
  17. #37 Re: horrible noise
    Didn't you put new brakes on it?
  18. #38 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
    Yes. And greased the slides. The noise has gotten worse and started on the other side too
  19. #39 Re: horrible noise
    it could be the axles, you have a cv joint, its like a U joint.
    any vibrations while driving?
  20. #40 Re: horrible noise
    Apr 2012
    Myrtle Beach, SC
    Slightly after you get up to about 70. But I think that's just the tires.
  1. Horrible Gas Mileage
    By Cody Benjamin in forum Engine
    Last Post: 04-22-2012, 01:51 PM
  2. 99 gtp running horrible need help
    By gtcoup in forum General Grand Prix Discussion
    Last Post: 04-06-2012, 05:22 PM
  3. Horrible mileage
    By tgarison in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2011, 10:59 PM
  4. Car getting horrible MPG
    By Mercenary in forum General Tech Discussion
    Last Post: 02-02-2011, 10:42 PM
  5. Engine making horrible noise.
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:24 AM
